- Way up north, UT
I got tired of constantly digging up the fastener torque specs for my H3's so I just put together this list of all the fastener torque specifications i could find the the H3's. This was mainly pulled from the FSM's on Schwarttzy's site. Eventually I am going to make groups for the various common trail repairs we have to do to make it handier to look everything up. I'm printing out a copy to keep in my truck so that I always have it with me. I am pretty particular about tightening to spec rather than "good enough" since "good enough" often really isn't. That's how stuff either falls apart or breaks/leaks/makes noise/etc.
Body:
Check Link Bolt 25 N.m 18 lb ft
Check Strap Nuts 9 N.m 80 lb in
Endgate Assist Rod Stud 10 N.m 89 lb in
Endgate Hinge Bolt 50 N.m 37 lb ft
Fender Mount Bolts 10 N.m 89 lb in
Front Side Door Hinge Bolts 25 N.m 18 lb ft
Grille Support Bolts 9 N.m 27 lb in
Hood Hinge Bolts 25 N.m 18 lb ft
Hood Latch Release Screws 2 N.m 18 lb in
Hood Latch Screws 10 N.m 89 lb in
Rear Side Door Hinge Bolts 25 N.m 18 lb ft
Brush Guard Bolts - Lower Short Bolts 50 N.m 37 lb ft
Brush Guard Bolts - Upper Long Bolts 85 N.m 63 lb ft
Brush Guard Nuts 50 N.m 37 lb ft
Front Bumper Bolts 40 N.m 30 lb ft
Front Bumper Lower Bolts 50 N.m 37 lb ft
Front Bumper Upper Bolts 85 N.m 63 lb ft
Rear Bumper Bolts 32 N.m 24 lb ft
Rear Bumper Bracket to Bumper End Cap Nut 32 N.m 24 lb ft
Rear Bumper Bracket to Frame Bolts 85 N.m 63 lb ft
Rear Bumper Bracket to Trailer Hitch Nut 85 N.m 63 lb ft
Rear Bumper End Cap Nuts to Bumper 32 N.m 24 lb ft
Trailer Hitch Electrical Receptacle to Rear Bumper Bolts 32 N.m 24 lb ft
Trailer Hitch to Frame Bolts 100 N.m 74 lb ft
Cargo Tie Down Loops 34 N.m 25 lb ft
Front Bumper Impact Bar Bolts 50 N.m 37 lb ft
Grille Guard/Brush Guard Bolts 50 N.m 37 lb ft
Radiator Grille Nut 3 N.m 27 lb in
Rear Side Door Flare Screws 2 N.m 18 lb in
Rear Wheel Opening Flare Bolts 9 N.m 80 lb in
Rocker Panel Screws 2 N.m 18 lb in
Windshield Side Reveal Molding Screws 2 N.m 18 lb in
Front Side Door Mirror Bolts 10 N.m 89 lb in
Rearview Mirror Screw 2 N.m 18 lb in
Wipers:
Front Wiper Arm Shaft Nut 21 N.m 15 lb ft
Front Wiper Motor Bolts 12 N.m 9 lb ft
Rear Wiper Arm Nut 9 N.m 80 lb in
Rear Wiper Motor Bolts 10 N.m 89 lb in
Washer Solvent Reservoir Nuts 10 N.m 89 lb in
Wiper Motor Transmission Bolts 10 N.m 89 lb in
Interior:
Sunshade Bolt 2 N.m 18 lb in
Rear Side Door Armrest Bracket Bolt 10 N.m 89 lb in
C Pillar Assist Handle Bolt 52 N.m 38 lb ft
Assist Handle Bolt 9 N.m 80 lb in
Rear Seat Cup Holder Screw 2 N.m 18 lb in
Upper Body Side Garnish Screw 2 N.m 18 lb in
Windshield Side Garnish Screw 9 N.m 80 lb in
Door Trim Panel Screw 2 N.m 18 lb in
Door Trim Panel Bolt 9 N.m 80 lb in
Sunshade Screw 2 N.m 18 lb in
Front Seat Switch Screw 2 N.m 18 lb in
Frame:
Assist Step Bolt 50 N.m 37 lb ft
Crossmember Bolt
First Pass 70 N.m 52 lb ft
Second Pass Plus 200 Degrees
Engine Shield Bolt 20 N.m 15 lb ft
Frame Cushion/Insulator Bolt 115 N.m 85 lb ft
Front Differential Assembly Bolt 100 N.m 74 lb ft
Oil Pan Skid Plate Bolt 20 N.m 15 lb ft
Tow Hook Bracket to Front Frame Rail Bolt 85 N.m 63 lb ft
Tow Hook Bracket to Rear Frame Rail Bolt 100 N.m 74 lb ft
Tow Hook D-Ring Nut First Pass 50 N.m 37 lb ft
Second Pass Minus Approximately 180 Degrees
Trailer Hitch to Frame (Horizontal) Bolt 160 N.m 118 lb ft
Trailer Hitch to Frame (Vertical) Bolt 100 N.m 74 lb ft
Transmission Crossmember to Frame (Vertical) Bolt 100 N.m 74 lb ft
Transmission Crossmember to Frame Bracket (Horizontal) Nut 50 N.m 37 lb ft
Transmission Mount to Support Nut 57 N.m 42 lb ft
Wheelhouse Panel Bolts 10 N.m 89 lb in
Exhaust:
Catalytic Converter Heat Shield 9 N.m 80 lb in
Catalytic Converter Nut 50 N.m 37 lb ft
Exhaust Manifold Bolt
First Pass 20 N.m 15 lb ft
Second Pass 20 N.m 15 lb ft
Final Pass 20 N.m 15 lb ft
Exhaust Manifold Heat Shield Nut 10 N.m 89 lb in
Exhaust Muffler Heat Shield 9 N.m 80 lb in
Exhaust Pipe Heat Shield 9 N.m 80 lb in
Leaf Spring Bolt and Nut 85 N.m 63 lb ft
Lower Shock Absorber Bolt and Nut 95 N.m 70 lb ft
Muffler Nut 45 N.m 33 lb ft
Transmission Filler Tube Bracket Nut 12.5 N.m 111 lb in
Cooling System:
Coolant Heater 50 N.m 37 lb ft
Coolant Recovery Reservoir Bolt 10 N.m 89 lb in
Fan Blade Bolt 27 N.m 20 lb ft
Fan Clutch Nut 56 N.m 41 lb ft
Thermostat Housing Bolt 10 N.m 89 lb in
Water Outlet Housing Bolt 10 N.m 89 lb in
Water Pump Bolt 10 N.m 89 lb in
Water Pump Pulley Bolt 25 N.m 18 lb ft
Body:
Wipers:
Interior:
Frame:
Crossmember Bolt
Exhaust:
Cooling System:
