Foldover Antenna Mount
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
Does anyone have a good recommendation for a foldover antenna mount that I could use for a HAM antenna on my Gobi rack? I'm looking for something durable that can be up when I want to use the radio stationary, and fold over to the down position across my rack when I want to be mobile.
I had one of those on my 05 H2 and it was great. I was using it for the CB and not my HAM radio. Mikkel had hos HAM antennae down quite a bit, hopefully he will have some intel.
LagunaH1
Idaho
*perks up* Did I hear a scotch bottle open? Oh wait... someone said HAM radio.... :D
There are many ways to do this. Couple of thoughts:
What band(s) is your antenna for? Do you want deployment to be automatic (well, powered at least) or manual?
If it's a big heavy HF antenna then you will need something very different than what's required for a light 2m/440 whip. Some go with a simple coil spring setup and tie the antenna down when you want it to lie down. This setup is great from a simplicity point of view, you just need to keep in mind that the spring itself will likely be part of the antenna, depending on your feed point. Also: Where is your antenna located? I'd guess it's attached to your roof rack?
Here's a couple of options to get your thought process started:
http://www.diamondantenna.net/Product_Catalog/mounts.html
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
I am still undecided on the antenna and radio. I'm just starting to really research this stuff, as I'm only a technician and not really familiar with HAM too much. What do you guys recommend for a durable antenna and radio combo that would give me the most bands?
I want an antenna mount that will allow me to lay the antenna completely down for wheeling, from the rear of the rack laying forward. I don't mind doing it manually.
DJinCO
If you want a QUADBAND 29/50/144/430 VHF/UHF TRANSCEIVER FULL DUPLEX the Yaesu FT-8900R. A really nice unit with 2M/440 50W 220MHZ 1W TRANSCEIVER MOBILE GPS/APRS/BLUETOOTH CAPABLE is the Yaesu FTM-350AR.
I would recommend either of those. If you want HF also, the Yaesu FT-857D, ALL MODE HF / 6M + 2M + 70CM MOBILE TRANSCEIVER
DJinCO
The ATAS-120 is pretty big. Not fold-over. I have seen them on a few cars; not really something I would want to deal with on a trail. Also, I don't really know how much HF you will be using while mobile. I think you could operate in a field setup with that antenna and FT-897D - more HF capability.
I find 2M to be very useful while out and about. The FTM-350 has a nice GPS/APRS capability that is VERY useful while off-road for tracking your path and route.
LagunaH1
Idaho
The ATAS 120 is super convenient for use of multiple bands but because it operates on multiple bands it *has* to compromise its efficiency on many bands. The ATAS is mostly meant to be used on HF bands. In my experience it is very convenient when combined with a Yaesu radio which can command it to change its configuration as you move between bands, but it is by far not the best HF antenna for pure efficiency.
Food for thought: When I'm out and about wheeling I use almost exclusively 2 meters and a little bit of 440. This gives me plenty of range to use the local repeaters and to talk to other vehicles in the group. To this end, I have 2 2 meter / 440 antennas that I use:
My primary antenna is a Diamond 2/440 (I forget the model number) high gain antenna, it has somewhere around 7 db's of gain on 2 meters. The down side is that it is very rigid. Due to the rigidity, I remove it and replace it with a much more flexible, but lower gain (around 5 db's as i recall), antenna when I wheel where there is low hanging branches.
To this day I still use mag mounts to hold my antennas because they act as a very nice mechanical "fail safe" if I mis-judge how low a branch hangs for example in which case the mag mount will let go, the antenna will fall over and make a heck of a noise but nothing will be damaged or broken.
LagunaH1
Idaho
Agree 100% :) Those are three very nice radios.
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
How about mounting? I want to avoid beating the crap out of my antenna, which is a huge deal in the eastern woodlands where I plan to retire. I want something that works well mobile and is strong enough for stationary ops when I'm camping. And my Gobi rack is a factor...
LagunaH1
Idaho
I think the choice is between something that folds down and inside your rack, so it's protected by the rack vs something that's flexible enough to bend and flex around branches, etc.
Do you want to be able to use your radio while driving?
You mention stationary ops... what does that mean to you? Keep in mind that as a rule of thumb, VHF & UHF is line of sight. If, for example, you have placed yourself on a hill top, then even a mediocre 2 meter antenna will get your signal out really far: As far as the signal can travel without encountering obstacles.
HF is a different beast altogether......
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
My target area is WV, so line of sight will be an issue for me. I'm going to have to bounce to reach distances. My preference is something that folds down inside the rack while mobile (I already have a CB for wheeling). I'd rather have something that I could set up while camping and still talk at distance.
LagunaH1
Idaho
Ok, in that case you will need to run HF, and also get a general or extra class license. VHF / UHF won't cut it for your needs.
Given this, I'd recommend you look at a HI Q screwdriver antenna for HF, and also get their "giant quick disconnect". This combination would allow you to remove the HI Q antenna when you are moving, and yet quickly and easily install it when you are stationary and want to work on the HF bands.
I use this combination and it's one of the better mobile HF antenna setups out there. I have worked Europe from Moab, the Falkland Islands as well as New Zealand and Japan using this type of antenna (this was when conditions were particularly good of course)
http://www.hiqamateurradioproducts.com/Antennas/480rt.html
