Polar Bear
- Montreal
So I got feed up hauling the winch cradle from the front of my H2 to the rear and I wanted a much more powerful winch that would better match the weight of my H2.
And honestly...I was feed up having to pull the winch cradle out just to be able to open the hood! And while it never happened...what if I needed to open the hood with the winch in place and under tension...not going to happen!
So I looked at every bumper from Road Armor to Iron Bull to you name it and I decided...I will simply build my own.
I did this in April of 2013...I am so glad I did it! One of the best mods I have done on my Deuce!
Here are the first pics of the bumper as it is stock with the receiver mount.
Here is the front frame with the bumper removed and the receiver exposed.
Here is a test fit of the winch mount that I had started to make about 2 years ago for a smaller 12000lbs winch.
One thing I already noticed is that I will need to completely change my initial idea. While I did want it tucked up as high as possible, the new 15000lbs winch requires me to drop the winch down lower on the frame both for clearance and strength of mounting. A standard 12000lbs winch is only 6 inches wide, this mighty 15000lbs winch is 8 inches wide and requires not a mere 4 bolts to hold it down but 8! So I will need to carefully plot out the new mounting holes to allow me to have the right pattern and strength.
The winch I will be using is the Smittybilt 15000lbs X2O, I want to be sure if I am stuck in the mud and I need to pull myself or several trucks out at a time it will be a breeze. Is it overkill...not really my H2 weighs just shy of 9000lbs!
Stay Tuned!
Stay Tuned!
