derian06
Red Rockett
- Madison, AL
So as you all know i'll be starting my engine swap soon after hitting a hole that was too deep and hydro locking the motor. First thing I need to start learning EVERYTHING and ANYTHING. About the 5.3L V8 engine and what I need to do make it work in my 2007 3.7L Hummer H3. So if anyone can help it will be greatly appretiated. The biggest things I need to know right now is, what needs to be changed to the transmission, and where to get a new PCM, ECM, ?TCM?, and BCM. Also if I should use and alpha's PCM or a I5's.
Thank You All!
Thank You All!
