My truck is far from finished. Just like everyone elses.
What are the important things left?
Hydraulic Bump stops. I have no bump stops whatsoever. I will be getting ECGS to install some Fox ones.
Ram assist skid plate. ECGS will also be fabricating a custom one.
Body protection. ECGS will also be doing some external tubing to protect certain body parts. Not really exo-cage. Something more along the lines what the Aussies do on their rigs. Trying to keep weight to a minimum.
Exhaust Wrap. R&J Custom Exhaust is going to do an exhaust wrap. It helps a lot with heat issues in the Alpha. Not doing it for performance reasons.
Power sterring pump. R&J will also be swapping out a PSC pump. I want them to do it just in case it doesn't hold up. I had originally installed it but it blew after 5 minutes of use. Had it rebuilt, and we'll see if this time it lasts longer. If not I'll do one of my rebuilds like I used to do to my TJ ones that have lasted forever after that.
EVAP relocate. I'm thinking of relocating it somewhere it's not going to get full of off-road debris. Also contemplating just putting it into a sealed tupperware, which in turn will have it's own breather/snorkel. The intake on the EVAP is too big to just add a breather to that. Will take some looking into and coming up with a solution.
Dual Battery setup. The Artec one is far from ideal. I need to find a better solution. I really haven't had the time to look for battery alternatives that aren't Optimas.
Atlas. That's way down the road but something I would eventually like to do. Won't be any time soon though. The fact that Bebe is already in the process, will definitely make life easier. Thanks Bebe.
All these mods are things that I would like to do, but who knows when I'll get to doing them. Hopefully soon.
