I have the schwarttzy and am generally pleased with it.
It can take a bit of finagling to get everything snug, avoid rubbing on the cable or rope, makes an extremely tight fit if you have an external tranny cooler, and the clutch handle might be difficult to actuate depending on which winch you use.
Some nice advantages is the discrete look, most of the rope is out of direct sunlight, it keeps the entry point very close to the center of the rails, and is pretty sturdy.
Someone mentioned once, can’t remember where, that it can induce twisting in the frame rails and possibly impact air bag and crash safety performance of the frame.
Not sure how that would be evaluated but I guess many of the aftermarket mounts could have the same problem.
