2010H3TAlpha
- Issaquah, WA
Per my other thread here, my 4L60E most likely has a damaged front planetary and needs to be rebuilt: https://www.hummer4x4offroad.com/forum/showthread.php?13351-New-transmission-noise-(Alpha-4L60)
I have decided to have a reputable local shop rebuild my 4L60E with some upgraded parts. I don't need to go too crazy (no 300m output shaft, etc.) but I wanted to share what we're looking at so far and see if anyone recommends anything additional while we have it open. Keep in mind that I am planning an LS3 next year, so being able to handle 500hp/500tq is important. Here's the list so far:
Sonnax Performance Pack:
Sonnax Smart HD Reaction Shell
Heavy duty 3-4 clutch backing plate kit
Rear stator support bushing
Corvette servo
Heavy duty 2-3 shift valve
4th gear super hold servo
Anything else we should consider while things are taken apart?
Thanks!
- 1-2 Accumulator Valve Shim
- TCC Pressure Limiter Valve & Spring Optional, eliminates PWM/EC3 function
- Boost Valve with O-Ring .490"
- Elevated Pressure Regulator Spring
- High RPM Pump Slide Spring
- Spacer
- 4th Servo Return Spring
- Servo Cushion Spring
- Servo Piston D-Ring Kit
- 3-4 Accumulator Piston Kit
- 3-4 Accumulator Spring
- Servo Release Check Valve
- Forward Accumulator Kit
- Checkballs (8)
- Separator Plate Plugs Not Shown
- Twist Drills Not Shown
- 1-2 Pinless Accumulator Piston Kit
- 1-2 Accumulator Inner Spring
- 1-2 Accumulator Outer Spring
- 1-2 Accumulator Waved Spring
Corvette servo
Thanks!
