GreatDaneHummer
- Chicago
Can someone explain how the system could still be active if you are removing the fuse effectively breaking the provided power to the system. There are not any capacitors to "store" remaining current or an on board coil pack etc.. This would be an easy test if you used a multi meter measuring any residual amperage. Yes removing a fuse from a socket does not "hurt" the electronics on board but over time the reliability of the matting surfaces of the fuse being rubbed in and out will eventually lead to a weak connection possibly making it intermittent. Just my 2 cents.
