- Tardville
So you want a solid axle in your H3? Grab a GM Dana 44...grab on of these kits...and start cutting!
These hubs come with ABS rings pre-installed and caliper brackets that allow you to bolt your H3 brakes to the Dana 44 of your choice. The brackets accept stock ABS sensors, and the 12mm studs even allow you to keep your stock rotors and lug-nuts. Don't do a hack-job! Don't settle for 70s-era brakes! Keep your ABS, TCS, and Stabilitrac functioning. I have several sets available in large and small bearing versions. For use with GM/Jeep spindles. $400 (including $50 core for 6-lug hubs).
