- Meridian, ID
I have been contemplating on what I should do for my switches. I had originally thought a great product would be the SPOD. They are used in jeeps and toyotas but nothing was made for the H3. I was originally going to fit and modify it to make it work but in the end it wouldnt be worth it. I then was going to make a mount by the shifter but then that idea went out the window. Months back Tim and I talked about a Pod above the rear view mirror but the concern was having it in the way of adjusting the mirror. I like that idea though, its out of the way, visible and keeps your eye on the trail. So I started to make my own. It will be mounted above the rear view mirror but isnt mounted yet so heres the pics of just sitting on the mirror. It shouldnt be an issue in terms of adjusting the mirror. Sorry for the bad pictures, I will finish it when I have time. It still needs paint, mounting brackets and final touch up of grinding down the welds and touching up uneven spots. I also need to add more switches for future lights, lockers, compressors, etc. Maybe Tim can do some donating so I can use all of the switches right away
