Mb30sdl
Hamster that pokes Bears
- Raleigh area NC
Looks like I am back and wana do some runs in September. Maybe 13 or 20? Is any one interested.
The GM dealer finally started working on my steering rack, thank god, might be able to make it if I can get 315s for my stock wheels.
Well in my case getting the mayhem steering mount kit probably is more important than anything else after experiencing a fail of the rack on the trail. Thanks to the H4O crew (reloader)for getting me home safe.
Where were you thinking for this trip?Looks like I am back and wana do some runs in September. Maybe 13 or 20? Is any one interested.
Honestly, no loyalty or anything else. Scorpworks, is best solution. Pricy, but know a bunch running his, zero issues. Have his crossmember in my 2. Has held up like a charm. Went through 2 OE crossmembers before his came out and no signs of issues.
That sucks. Have a shop confirm before you buy a CI. I priced them recently and they ain't cheap.I am out, probably for the rest of the year.
I think my front diff is going out. I have been hearing dome weird noises from up front. Gonna drop the front shaft and drive with rear wheel drive only to see if it clears up. Unfortunately, the H3 is my every day driver right now. I may end up dropping the front diff all together and get it rebuilt or find a replacement. Not sure if the cast iron model can still be found.
If you need a "new" front differential you can have my old front differential, I pull a little back when. I put in the cast iron one. Let me, all it will need is new cv seals and perhaps a differential cover seal of you decided to crack it open...if not the. You don't need that either, nothing worn with it.
Torres
I may take you up on that. CIs are looking out of my price range right now. I am going to try to pull mine out this weekend and see how bad it is. I have a serious clunking noise and the diff is the last thing I need to look at. I already have gone through all the diff mounts (including a ScropWorks cross member) along with a new drive shaft and of course, new half shafts. I will get in touch when things mellow out a little more at home and I have the In-Laws settled in their new place.
