New Hummer Owner
snoman48
Poughkeepsie, NY
Hey all,
Just picked up my 2008 H3 Base, Manual tranny on monday, and am loving it so far. The forum has been a great read so far, especially seeing builds like ReconH3's. I'm a sucker for military stuff, being a USMC vet myself. Few questions about the truck that I haven't found clear answers to yet.
The rear dome light is inop, I replaced the bulb but no joy yet. When I pulled down the assembly, there doesn't seem to be any corrosion or breakage in the wiring or connector. Is there a seperate fuse for that circuit? I don't have any other electrical outages as far as I can tell so far.
There's a pretty hefty clunk when accelerating from a stop in 1st and the shift to second. I thought it may have been the jack in the tailgate, but I've tightened down the holder as tight as I dare with that plastic disc, still exists. The spare isn't mounted loose either. Any ideas?
Finally, I stopped at a gas station on my way into work tonight to grab a pick-me-up (gotta love working nights), and jumped out of the truck and left it running (still pretty cold here in NY). I came back to a completely locked truck, keys, phone, everything inside. Had to have the wife drive to the gas station with my spare key. Any idea how I can avoid that in the future?
Sorry for the wall of text with my first post, but I look forward to absorbing the collective knowledge here, and hopefully offering some insight as I go!
Expendable
Burbank, CA
Thanks! Any ideas on the mentioned issues? Nice to see I'm not the only one who's up all night :)
you're welcome!
I'm not sure about the first two and not sure my ideas on the third issue would be of help. which is why I originally mention anything.
for the door locking issue I can think of:
- if you have a clicker and a key (not sure if they do but I think they would considering it's a GM) I would keep the Key on one ring attached to a Carabiner and the clicker on a separate ring on the same carabiner. then when you leave the truck with it running. you can lock it and unlock it form outside.
- leave the driver's window down when leaving the truck (you mentioned it was cold so not sure how much of an option this would really be.
Welcome from So Cal. The clunk could possibly be the front diff crossmember or the side diff brackets
snoman48
Poughkeepsie, NY
Thanks all for the welcomes and ideas! Can anyone suggest a good online microfiche for parts diagrams? I've never been a huge fan of Rock Auto's setup.
Anyone else have an issue with the rear dome light?
Nally gmc has probably one of the best catalogs online that gives you part numbers. It is far from complete. When chasing the clunk, if it is the crossmember. Check out Sorpionworks here. He is a sponsor and has an awesome replacement
Dome light is an odd issue, I don't have an answer either. I think Zach has you covered on the cross member and parts. Welcome to the forum
snoman48
Poughkeepsie, NY
Thanks gents!
My H3 is just about to come up on 60k on the clock, any maintenance items I should investigate, problems I should start looking out for?
Again, it's a 2008 Base, I5 5 speed manual tranny
snoman48
Poughkeepsie, NY
Also, has anyone seen this stuff from Smittybilt? http://www.smittybilt.com/gear.htm
I'm thinking of trying to make their MOLLE overhead console work for the H3, being that it's lacking in the having one department:shifty:
I'd love to try and make the tailgate cover fit too, and just relocate the jack somewhere else. I've emailed Smittybilt for dimensions, but haven't heard back yet.
snoman48
Poughkeepsie, NY
Great H3! Do the seat covers tend to slide around much getting in and out?
I'm more interested in the overhead console and tailgate cover for now, my seats are in great shape, and I need to be able to fold down the rear flat without any obstructions.
Thanks for your service BTW, where'd you earn your Bronze Star? (if you don't mind my asking, USMC Vet here)
cbetts
NERD!!!
Rancho Palos Verdes, CA
Greetings from Southern California! It is great to hear about another H4O member with a manual. I had to order mine back in 2006 to get one with the adventure kit.
Did you check to insure the light bypass is off? It is located to the lower left of the headlight switch/knob.
As far as the clunking issue, I suspect the rear door latch is loose. It happens from continuous slamming of the door and loosens the wedge. I had mine fixed several years ago under warranty and so not know how to fix it. Once the service writer explained how it happened, I became more aware of my actions. Now I just slam it into rocks! :giggle:
Several of us that go off roading have locked our keys in the truck. All I can suggest is to double check your lock status before jumping out or don't leave it running unattended and take the keys with you. I normally carry a second key in my pocket when wheeling since I tend to get distracted by the trail.
