HummDinger
- United States
Some background: 06 hummer h3 with 110k, 35" mickey Thompson atz, leveling kit and I do quite a bit of wheeling but nothing real crazy (I live in Michigan).
So I started out with a loud wooing noise coming from the front axle area on deceleration. I couldn't pin point the problem by driving it down the road so I put all 4 corners up on jack stands and put it in drive, speed up to about 35mph and then decelerate by simply letting my foot/hand off the gas.
In doing so I was able to listen to each part of the drive train with my stethoscope. Nothing sounded bad on deceleration until I put my stethoscope on the front differential, then putting it under the driver side carrier bearing I could here that the wooing was very loud right there.
So with this discovery I proceeded to change the carrier bearings out, put it all back together to find no change in noise.
Scratching my head (while reading these forums) I decided to go ahead and purchase a new half shaft for the driver side since the noise was definitely coming from the drivers side. Changed it out and still the same wooing bearing noise on deceleration that does not change going around a corner or hard turns left or right, so it shouldn't be a wheel bearing right?
I decided to take the front Driveshaft out to see if it made a difference and it did, the noise seemed to had disappeared.
So with this new found knowledge I decided to purchase a new cv for the prop shaft as well as a new u-joint, put it all back together and the noise is still there and getting worse/louder it every trip to work and back (bout a 45miles round trip) and I'm not real sure where to go from here.
Any help/suggestions would be greatly appreciated.
Thanks so much for your time and effort
