- Way up north, UT
I'll tell you what, finally breaking down and buying a 20 ton shop press and an air hammer were a couple of the best decisions I have made yet. Life changing, seriously. What used to involve lots of blood, sweat, tears, fire, and sacrificing to the automobile gods, as well as several hours of your life, has been reduced down to mere minutes of relatively easy work.
Pressing out the old front bushing:
Pressing out the rubber from the outer diff bushing:
Which it turns out I probably didn't need to push out the rubber and inner metal sleeve of the diff bracket bushing, since I was able to just take my air hammer and hit the outer metal sleeve of the bushing from the back and they popped right out. Last time I replaced those bushings it involved an hour or so of burning out the rubber and then slitting the sleeve with a saw, then peeling out the sleeve. Lots of wasted time, and it damages the paint/powdercoating of the bracket.
Pressing in the new front bushings wasn't too bad either. I knew it was going to be a bit of a challenge due to the shape of the bushing (here is a link to the Siberian Bushing replacement, it's shaped exactly the same as the OEM rubber one and either is a one peice unit: https://www.amazon.com/Bushing-32-06-2330-Front-Susp-Lower/dp/B00WJKS2QS ). I took my time because I didn't want to accidentally tear the bushing, but using the grease that was provided and slowly working the lip of the bushing down into arm I was able to relatively easily get them pressed in. It would definitely have been a huge pain to try and do that with a ball joint press.
Speaking of which, here is the setup I used to press in the new rear lower control arm bushings using the ball joint press I rented from Autozone:
You do have to have the differential at least unbolted from the sides, I still had the center bolt in place and just pivoted the differential to make room, though on the passenger side it was still a tight fit. I could not get the ball joint press to sit correctly from the outside as the throat of the press is not deep enough. But overall it went together pretty smoothly. You have to measure where the old bushing sat in relation to the cross member as you do not press the bushing all the way in, and if it's not in the right place then it doesn't line up with the front pivot of the arm. Make sure though to not press it in too far, as the outer metal sleeve of the bushing is a bit cone shaped and if it goes in too far and you have to back it out, it probably won't be tight in the crossmember anymore and can cause issues. Better to not press it in far enough, check the alignment with the arm and then press it in further to get it all lined up. I did that on each side and while you'd think a millimeter or so won't make much difference with getting the arm in, it really does.
