First H3!
LagunaH1
Idaho
Welcome to H4O and congratulations on your H3. The '3 is a GREAT truck, looking forward to seeing how you personalize it. Oh, and, that whole "taking the long way home" disease has infected everyone here so you are amongst peers. :cheers:
Paladine71
ΜΟΛΩΝ ΛΑΒΕ
Tallmansville, WV
I still have to get some tires and things before I'll even consider taking it off road. I refuse to be bunny slope fodder :p
I wouldn't worry too much about being fodder in an H3. They are extremely capable even stock. If you do want to hit the trails with us, better tires should be your first priority.
JUGG3RNAUT
Davenport Iowa
That's what I figured, bare minimum I'd get some better tires and it should handle ok from there on the trails.
I just found out last night that the E-brake doesn't work. I pushed with all the might I was willing to give it, without braking the pedal right off. It's like the lever is stuck or siezed. Anyone know of a good way to check / see what might be wrong?
Silverton34
Phoenix, AZ
:giggle:Great looking H3. If you want some more chrome for it I have a set of factory chrome nerf bars you can have.:giggle:
I live just north of you in Eldridge. If you need a heated garage to get your e-brake fixed just give me a holler, the garage is available and a little assistance.
JUGG3RNAUT
Davenport Iowa
Thanks! I found out from the dealership that the lever is seized and the cable is broken. I need to do a bit of research and find out how much parts are, I'm sort of mechanicaly inclined but not enough to tackle it blindly, I appreciate the offer and will definitely let you know if / when I get the parts.
H3DONIST
USA
He's already got chrome factory nerf bars and I'm pretty sure he can only use one set of nerfs at a time. :wink:
Silverton34
Phoenix, AZ
We could probably make two sets fit on there if he really likes them that much!:)
Let me know if you want help and a warm garage to install the new cable, they are not difficult at all. I'm off work until Tuesday.
If you have time check out www.qcjeepers.com it is a local club that a friend started and is not just Jeeps. We will likely have a New Years Day run somewhere close on private ground, should be fun and you are welcome to join us.
