brschwan01
- Ohio, US
It kinda defeats the purpose of asking the question, if you tell us what you did doesn't it.........
[emoji14]
The build is coming along nicely!
How much to get you to make another set!? Those look great?Had to get the shocks installed ASAP, as I'm not a very patient person.
Took some quick/rough eyeball measurements of what I was working with, and fired up Solidworks. Tossed together a super quick/simple bracket for the reservoirs and cut out the pieces on the plasma table. TIG'd the pieces together, and then mig welded them to the shock towers. The placement worked out great. At closest point of contact, the tire is still over 1.5" away from the reservoir.
Not many pics taken, as I was in work mode, and just trying to get stuff done. I'll get some better pics in the next couple days.
Simple design pic:
Next few pics are with the front suspension unloaded with a floor jack:
This is a quick pic showing what it looks like at ride height (23" from hub to fender):
Looks nice! Let us know how's those rotors and pads work for you.
Sure amNot sure. Are you running the same shocks on your rig?
Did you get the new hub in? Was it a tough install?
Were you hitting the metal stop before adding the upper bump stop? If you have not lengthened the sway bar links and those shocks are longer and your running stock tie rods I wonder how that was happening.
Do you think adding that upper bump stop will limit travel to less than stock?
I have been eyeing that instant air supply setup on pirate. let me know how it works out for you
The place where I fill my co2 bottle for my beer just does a bottle exchange so don't get too attached to that bottle. If you want that bottle filled in most places it is done off site somewhere and it has to be sent off and you will have to wait. It may cost more to do it that way too.
