6 speed manual swap
GreatDaneHummer
Chicago
If you had a 5 speed manual H3 and wanted to swap to a 6.2l with a 6 speed would the 6 speed line up the same as the 5 speed making the swap easier? Lots of time on my hands at work these days so thought I would throw it out there.
What is the length of the 4l60e in the H3 currently?
atvspeed4
massachusetts
There is another thread on here where I discussed this. Try searching for it and let me know if there​ are further questions
Sent from my Pixel XL using Tapatalk
CaseyS
Louisiana
From memory on the top of my head. OAL from bell to transfer case flange is about 26.5" on both the auto and manual 5. The shift tower is about 25" aft of the bell face based on my approximations from pictures.
The shift tower mounted in the front inspection port on a t56 is 19" aft of the bell face. A 2wd t56 looks like it would poke up in the right place but what good would that do.
Edit: also what 6speed 4wd box are you talking about? That doesn't exist in the GM OEM world.
GreatDaneHummer
Chicago
Rockland Standard Gear makes a T56 6 speed in a 4x4 configuration. I was just wondering if it would actually line up correct underneath to poke up in the correct place.
GreatDaneHummer
Chicago
Casey, are there any computer issues that I would have with switching from the 4l60e to the RSGear T56? I know mechanically I can make the swap but if there are computer issues that come about I would have to get outside help.
atvspeed4
massachusetts
You would need to reprogram for manual transmission. Also might be issue with stabilitrac as that only came on automatic H3s. All can probably be overcome if you could flash pcm/ bcm for manual version
GreatDaneHummer
Chicago
I will reach out to PCM of NC again and see if they can help in that area or what their knowledge is. Would you get errors also going to an Atlas 2 Speed T/C? I know there is an H2 running one without issues but I am not sure if anyone ever did it to an H3?
atvspeed4
massachusetts
Yes. There will be errors
GreatDaneHummer
Chicago
I guess the better question is; can the factory 4:1 transfer case handle 400hp / 400 ft lbs of torque with some aggressive driving?
CaseyS
Louisiana
Would this be starting with an alpha or an I5 to a 5.3/t56 swap? Either case I would think that stock tunes can be had rather easily for a manual base tune.
The chassis work would be common converting to the clutch switch and neutral safety. For an I5 swap, you would have to see if any of the interface wiring that is customer complete changes between ecm and bcm/chassis.
GreatDaneHummer
Chicago
I have a 2007 Hummer H3 with the 3.7 . I was finally able to get ahold of Rockland today and he is very familiar with the H3 driveline. I plan on using the LS3 430 crate motor due to the $500 rebate etc. The T56 6 speed 4x4 trans is $4700 with mounting plate for the 4:1 factory transfer case. From face of the bell housing to the linkage is 19" so it should line up in the factory position pretty close. The GTO offset is 2.5" so with that it "should" be very close to factory spot. All in plus accessories I am looking at around $11,000 for an entire new driveline. The 4:1 transfer case is only a few months old so its basically new already. It seems like a pretty good price compared to the dealer asking $4800 for a new 3.7l engine with reusing my existing accessories etc. What do you think Casey?
CaseyS
Louisiana
http://image.customclassictrucks.co...ssion/45374853/1301cct-29-o-tremec-t56-magnum
This shows the t56 with the shifter in the front position where it will be for the RD gear application.
This is the ar5 at OAL of about 26.5". I estimate the shifter 25" aft of the bell. I think you are looking at a 6" difference or the shift nub right at the radio face.
GreatDaneHummer
Chicago
That would be some odd linkage that would have to be made then. Even with the GTO offset its still 3.5" too far forward and there is no room for the engine to sit further back.
How much power do you think your putting out of your 5.3 supercharged?
The stock 5.3 is rated to 300 and Magnuson says their system adds 125 plus I have 3" exhaust high flow cats and a magnaflow exhaust so... also not sure if it were rated at the crank or the wheels....
I had my truck tuned on a dyno but we never did a pull to see the output
GreatDaneHummer
Chicago
Do you feel the power is "enough" for enjoyment then? Can you drive down the highway at 75 without downshifting or gear hunting?
Haha yeah it's plenty! I have hardly ever used it all and have never had the need for more.... Well the need come in the form of stronger front diffs and trans so I can use the power more often without worry
Hp tuners allow you to switch from auto to manual. Its just one parameter that will need changing!
GreatDaneHummer
Chicago
I am really against Hp tuners credit based payment system. It is a horrible business plan that makes me never use them. There are a few custom tuners here in Chicago that can help with any software / computer adjustments that I need.
GreatDaneHummer
Chicago
The email from RDGear says shifter location is 19" from engine and 29" over all to adapter and your saying the factory 5 speed is 25" from the engine back? Is there any GM specs that show the exact specs on the factory 5 speed?
