Starting to collect parts for a new project. Following Aventr's path with the hardware side of things. Will be using a cut down 27 spline output shaft and a TBSS adapter. Software side will include a TCM-2650 standalone from Zero Gravity. I'm early in the process working through all the detail stuff. First one right now is torque converter depth differences with my flexplate setup.
Transmission here is a 2011 with only 40k miles that I scored for $800. I have to open it to get to the input shaft so it will get an internal inspection before it gets bolted to anything.
Details will follow as they begin to trickle in. Not in a rush yet on this, likely spring completion.
