Like many know here I have put on all types of tires on my H3, changing them like new shoes but a light weight 35" tire is not bad. I have done the PCM tune, air doc, full exhaust, new throttle body and all new spark plugs etc (tune up). With all this it drives pretty close to the same as 33" tires using 67 lbs 35's... When I change to a heavy tire 85 lbs 35.20" tires then you do noticeably still have down shifts and power issues. One thing I do to help out is get all the extra weight out of it when its not needed. Take out rear seats, remove the roof rack, take off the extra skid plates and even remove the spare tire if I am just local mall crawling. It helps a lot. It may not look at pretty but Lord knows it helps with the gas.
