H3 Roof Racks
Nacho
Now with Chese
The topic of roof racks for H3’s seems to come up regularly so I have created a guide of what options are still available for the H3s. I’d like this thread be a reference for members so those with any rack post up pictures and write a review. Also could replies be kept to reviews or information from vendors. thanks
H3 Specific Racks
Gobi Racks
Gobi is considered by most to be the top roof rack available for the H3. Gobi racks are made of fully welded tubing and have traversable expanded metal decking and are finished in an epoxy powder undercoating with a textured black powder coated top coat. All versions of the Rack have 4 light mounting tabs in the front and two in the rear except the short rack which only has the two rear brackets. 1 1/8” tubes are welded into the rack allowing for Yakima or Thule accessories to be attached.
Stealth
photo courtesy gobi.com
Ranger
Ranger with a spare tire mount
Short
• Product number: GH3 (Ranger) GH3T (Ranger w/tire mount) GH3STL (Stealth)
• Dimensions:
• Finish: Grey epoxy powder undercoat, black textured powdercoat top coat
• Weight: 52lbs
• Capacity: 300lbs dynamic 600lbs static
• Number of mounts: 8 Roof mounts
• Price range: $1400-1500
• Website: http://www.gobihummer.com/H3.htm
Gobi Accessories
• Hi Lift mount
• Axe/Shovel mount
• Awning mount
• Tool boxes
• Rear door Ladder
Baja Racks
Baja make two racks specific for the H3 the expedition and the Standard. Baja Racks are made of 1” carbon steel tubing with a zinc primer and black powdercoat finish. The expedition rack is the same length as the standard but the back 57” are flat allowing for the mounting of a roof top tent.
The standard
photo courtesy columbiaoverland.com
• Product number: BR-HM-H3-1-0
• Dimensions: 51” wide x 91” long x 6” tall
• Finish: Zinc primer with black powder coating
• Weight: 65lbs
• Capacity: 300lbs
• Number of mounts: 6 Roof mounts
• Price range: $750
• Website: http://www.bajarack.com/hummer
Expedition series
photo courtesy bajarack.com
• Product number: BR-HM-H3-EXP-1-0
• Dimensions: 51” wide x 91” long x 6” tall (flat area 51” wide x 57” long”)
• Weight: 52lbs
• Price range: $710
• Website: http://www.bajarack.com/hummer3-h3-exp
Baja Rack Accessories
• High lift Jack mount
• Axe Shovel mount
• Spare Tire Mount
• Light bar for 7” lights
• Light bar for 10” lights
• Awning mounts
• Dual gas can holder
• Light Harness
ARB
ARB makes one rack for the H3. It is constructed of tubular steel and is finished in a gray powdercoat. The floor is available in steel mesh or rung/bar styles.
photo courtesy arbusa.com
• Product number: 3800020M(Mesh floor) 3800020(rung floor) 3768010 (fitting kit)
• Dimensions: 49” wide x 73” long
• Finish: Gray powdercoating
• Weight:
• Capacity: 250lbs
• Price range: $420-$500
• Website: http://www.arbusa.com/Products/Vehicle-Application-Guide/HUMMER-H3-Accessories/114.aspx
ARB Accessories
• High lift Jack mount and shovel holder
• Wind deflector
Defender
Defender offers two variations of its rack for the H3, a bolt together rack and a one piece welded rack. They are built of 16 gauge 1” round steel tubing finished in a black texture powder coat. The racks come with welded light tabs four front and two rear.
photo courtesy cbetts
• Product number: 40504 (One Piece), 40505 (bolt together), DS24-6 (fitting kit)
• Dimensions: 48” wide x 60” long x 4” high
• Finish: Black textured powdercoating
• Weight:
• Capacity: 250lbs
• Price range:
• Website: http://www.defenderracks.com/racks.asp?year=2008&make=Hummer&model=H3&rack=1&prdt=
Defender Accessories
• Axe/Shovel mount
• Spare tire Mount
• Light Cage for four 9” lights
• Wind deflector
Garvin Wilderness
Garvin offers their Sport Series rack for the H3. The Rack is modular and made from ¾” square tubing finished in a black powder coat.
• Product number: 36010
• Finish: Black powdercoating
• Weight:
• Capacity:
• Number of mounts: 4 Roof mounts
• Price range: $550
• Website: http://www.wildernessracks.com/roof_sport_rack.html
Wilderness Accessories
• Gas/water can Mounts
• Yakima/Thule crossbar adapters
• Axe/Shovel mount
• Spare tire Mount
• Light mount Brackets
• Wind Deflector
Nacho
Now with Chese
Universal Racks
Yakima
Yakima suggests their larger basket the megwarrior for the H3 but the smaller Loadwarrior also fits. They can mount to the factory crossbars or to Yakima crossbars. The baskets are constructed of Heavy duty galvanized steel tubing finished in a black powdercoating. The baskets come with wind fairings.
Megawarrior
photo courtesy yakima.com
• Product number: 8007080
• Dimensions: 48” wide x 52” long x 6.5” high
• Weight: 35lbs
• Capacity:
• Price range: $400
• Website: http://www.yakima.com/shop/cargo/gear-baskets/megawarrior
Loadwarrior
• Product number: 8007070
• Dimensions: 39” wide x 44” long x 6.5” high
• Weight: 25lbs
• Capacity:
• Price range: $270
Yakima Accessories:
• Axe/Shovel mount
• Spare tire Mount
• Wind Deflector
• Stretch net
Rola Racks
Rola racks are made of steel tubing with a black powdercoat finish. The rack comes with a wind deflector.
photo courtesy Hunner
• Product number: 59504
• Dimensions: 40.5” wide x 52” long x 6” high
• Weight: 40lbs
• Capacity:
• Number of mounts: 4 mounts to crossbars
• Price range: $200
• Website: http://www.etrailer.com/Roof-Cargo-C...ola/59504.html
Rola Accessories:
• None
Nacho
Now with Chese
I currently have the Garvrin Wilderness sport series rack. I like that the rack is light weight, I'm guessing in the 35-45lbs range. It has a low profile design so I can still fit in parking structures and has an aerodynamic front. I have not noticed any wind noise from the rack but it has had wind deflector installed. I like that they make yakima adapters so I can mount my kayak saddles to the rack. The modular design of the rack also made it easy to mount brackets to hold my ARB awning.
What i don't like about the rack is that the floor is modular and the bars do not extend all the way to the front and back of the rack leaving a dead space at either end. The bars also sit up about an inch from the bottom effectively making the rack shallower.
H3slate
Brush raked
Tualatin, Oregon
Great thread, GOBI has a new short rack for the H3.
I had a yakima gear basket that attached to the oem cross rails. Looked good, was easy to take off, and had mounts for a shovel and hi-lift jack.
The hi-lift made a lot of noise when mounted, probably would have been less if I actually put stuff in the basket. It was a good removable basket for a decent price. You could also mount a bike rack, ski rack to the rails built into the basket.
those are some nice racks :wink: I love the gobi and the 2nd spare is nice to have. The only issue with the spare is the higher center of gravity. I get concerned of the COG when I tackle tougher off camber trails or if I ever lift mine. It also might be me overreacting too and it may not make much of a difference, who knows....
Cbetts' rack is also looks great too. It really gave him that rugged offroad look.
Hiding in a potato patch in Idaho
I have the Yakima load warrior; the mega was too large, in my opinion (lengthwise). Also, stopped using the factory, flexible POS cross bars and installed a pair of Yakima towers and steel cross bars. The stock bars would flex when loaded on a dirt or rough road and bang against the roof. The Yakima bars hardley flex at all.
Portager
Silverado
And it is at my local dealer, although it seams a bit over priced and under built to me.
Is that plastic in the corners holding it together?
I also worry about wind noise. Wouldn't want to drown out the tire howl!
M22KLARS
Unsafe At Any Speed
Minnesota
Amstar/Boulder Accessories Roof Rack
(Not Available from Retailers any longer)
Black powder coated, all aluminum construction, weighs approximately 80 lbs.
Comes in two pieces and has TONS of places to tie stuff down.
I've been very happy with mine.
I have a Rola for my T and it is the perfect size for the shorter roof...it's loud as heck on the road though.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
jakesz28
Cabool MO
I went with the warrior products universal roof rack and universal brackets. I ordered these before I found this thread.
Rack is part number 81740. It is 55x65x5 inches.
Brackets are part number 43060.
I made my own t-nuts.
H3slate
Brush raked
Tualatin, Oregon
The Warrior rack looks good. They are just down the street from me. A few years ago they made some shackles available to us H3 owners. There was talk of trying to get them to make more products for the H3, but they weren't interested.
H3slate
Brush raked
Tualatin, Oregon
Here are some pics of my Knight Metal Works H3 expedition rack. It was custom made by Scarsman. It has multiple tie down points in the cargo area, a hi-lift jack mount, two removable ammo boxes, and room for 4 6x9 KC lights up front.
More pics and ordering info is available here: http://www.knightmetalworks.com/pages/main_site/home.html
There is a new Adventure H3 rack that should be unveiled soon.
