Project Angry Orange
Real4WD
Wherever the Army Sends Me
20240830
Installed new Outfitter Design front driveshaft. The OEM unit's CV joint failed.
Real4WD
20260530
Replaced some interior parts with units in better condition. For the combo pics, the old panel is on the left..new on the right.
-Rear Seat 40 Split Back Panel (Upper) (GM#JC-596802-5979)
-Rear Seat 40 Split Back Panel (Lower) (GM#JC-603378-5978)
-Rear Seat 60 Split Back Panel (Upper) (GM#JC-603396-5980)
-Rear Seat Mount Center Strip Cover (GM#JC-600637-5981)
-Rear Door Jack Cover (GM#AFH-79377-B-5840)
Real4WD
20260614
-Replaced the glove box (and transferred internals) with a nicer unit. (GM#21997795).
-Transferring the RPO code decal was a trick. At first when I tried to peel it off, the sticker started to fall apart. I had to resort to science to remove it without damage. Turns out, if you bake your glove box in the oven for 10 minutes at 250 degrees, it heats up the decal adhesive enough to release from the panel. Throw some new spray adhesive on, and viola! All the decals were transferred without damage for a "numbers matching" unit.
