3rd back seat , help needed
JAMerolle
Long Island
I have 3 children 8, 5 and an infant and all needing car seats. I was wondering if anyone is looking to part with there 3rd back h1 seat I would welcome it. I am trying to avoid the $1500 price tage I have seen at various hummer accessories sights. If you might want to sells yours contact me a bplateaus@gmail.com.
Any advise on seating would be great.
Cyouincourt007
Pavement Prince
Miami,Fl
I'll keep an eye out on local stuff down here and let you know if I see anything....I could swear I saw something recently on Craigslist but I think it was for an H2.
JAMerolle
Long Island
Hey Guys , this is for a 94 H1 hard top . Will the H2 seat work for the H1? I posted the same post on hummer forums and a guy responded and said he has one. Perhaps he will sell it.
mudbug
trail blazer
Brighton,Co
If it would work I think it would be some fab work involved unless your getting all the mounting hardware, then it would turn into guess work on mounting the brackets. A easier option might be a jeep fold and tumble rear seat but you will have to add seatbelts.
http://www.quadratec.com/products/24276_1XX_PG.htm. I haven't been in or under a lot of H1s so I'm really not sure what will actually work.
JAMerolle
Long Island
For a professional job that is safe who would you get to do the install ?
JAMerolle
Long Island
Mudbug Can you post a hyperlink to see what version your talking about. There is a guy from hummerforums that has one for me but no shoulder straps.
Clarke
SE PA
The mounts are actually enclosed monster Rivnut's that go through the body and into the reinforcement beams underneath. You won't be welding the tie-down nut into place - the body is aluminum. The mounting holes for the tie-downs/bench seat base are designed to take a 1/2-13" bolt - most places without specialized equipment will not be able to install the factory part/rivnut. You might be able to drill and put standard bolts/nuts through the holes but getting to the nuts above the fuel-tank will be a challenge - which is why they went with a rivnut style insert.
David - how did you get those retrofitted to your '92? The dealer added them in the back of my 2000 HMSB - but I don't know how they did it.
Thanks for the tips guys. 3 hummers can you tell me the measure coordinates so I can weld them in the right location ?
JAMerolle
Long Island
Thank you sir for this information. There has to be an easy solution.
Ron B
Los Angeles
Hi all -- been absent a while. I have one of the hummer bench seats and mount (at least I think I do...gotta check the basement) but I went with a custom fabbed mount and kids racing seat. Keeps the kid lower and can use a 5 point harness -- it wasn't that much money to fab, but a nice seat/seats with belts can be pricey if you go with nice ones (worth it). These are the only pics I can find quickly
RB
Mike S at Tustin added them so I could mount my Safari rack between the rear seats. They are just held in place with regular bolts and lock washers.
Clarke
SE PA
Right just just getting one with shoulder straps is the key
i had a local 4x4 shop fabricate a belt-bar loop behind the seat to allow for 4-point belts. Was quick and affordable. My son loved to climb up into the middle seat and hook up his four point harness.
