rollerlocked
- Wendell, NC
I am looking to do get some maintenance caught up on a new vehicle ( I have no idea if anything has been done with it in the past) .
The vehicle is a 2007 hummer h3 3.7 with the 4l60e .
1. I want replace the transmission pan with one that has a drain plug, and in the process replace the transmission fluid and filter . I am looking at the below pan and have read about clearance issues with any extended capacity pans, the pan below is listed as a standard depth 2 quart pan , has anyone on here used this pan or have any recommendations on which pan to buy .
hughes performance HP3782e
http://www.summitracing.com/parts/hup-hp3782e
2. Next up is fluid for the transmission, I am looking at the RedLine D6 fluid, does anyone run it, or is there a special fluid you guys would recommend for the transmission.
Redline D6
http://www.summitracing.com/parts/red-30704/overview/
Redline D6
