I've read a bunch of stuff on this, but wanted to see if there was any new wisdom.
2006 H3. I've had the issue before where you drive for a while (like on the highway) and when you exit and stop you get the oil light. I swapped out the oil pressure sender almost a year ago and that problem went away. Recently I've started getting the light coming on at random times, not just while coming to a stop. I changed the oil this past weekend and it's still doing it. I'm using Valvoline high mileage 5w30 and a PurolatorONE filter. Do you think the sender may be bad again? The replacement I used was an ACDelco. I've read about maybe going with a higher weight oil as well. Any thoughts on this? Everything else seems normal. No new noises, temp is good, etc.
