I need help, please. I have a 2006 h3 with the adventure package—140k. Never took it off-roads. At about 2k-3k rpm’s I have this resonant metallic vibration when I accelerate. Front end—mostly on pass side. It sounds like a heat shield rattle, but it’s not.
Replaced manifold shield and thought the shield could be slightly off.. I drove the car without the shield to test it—vibration was still there. Replaced both motor mounts(it did need it but sound is still there), replaced both hubs (left side needed it), replaced crossmember bushing (needed it, used Polyurethane one), replaced steering rack bushings (as a precaution with Polyurethane, but they were fine), replaced trans mount which looked fine. Replaced both bump stops for lower control arm. Replaced all 4 sway bar links.
What could it be???
What could it be???
