Page 34 of 34 FirstFirst ... 243031323334
Results 496 to 509 of 509
  1. #496
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,887
    Thanks
    1,184
    Alright so I briefly thought about selling my T, had some offers but st the end of the day I couldn't bring myself to sell it.
    So that being said the Mods will continue!!!
    Then plan is to take it up to Alaska for summer 2019 and down to Baja winter 2019.
    So with that in mind there are some things that will be done to make sure it's up to the task!
    First things first the trans cooler will be separated from the radiator via a Mishimoto HD cooler with electric fan. I will have a temp switch on order as well, it turns on at 180F and turns off at 160F.
    Next will be a custom tcase skid (loose the OEM skid I have currently to gain some clearance)
    Then it's going to be a full upgrade to the sleeping quarters.... I sold my RTT and I have plans for something much greater.... but likely I will put that into it's own thread when the time is right....
    The main thing to take away is that this build is not over!!!!
    2009 Hummer H3T Alpha
  2. The Following 2 Users Say Thank You to RamRod For This Useful Post:
    Hummer4ever (02-20-2020), jphh20 (12-23-2018)
  3. #497
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,887
    Thanks
    1,184
    So here is the big question! should I SAS my T?
    I have no choice but to replace the front e-locker as I noticed some damage to the "ramp" part of the locker.
    Once that is replaced I could either:
    1- Rebuild the front and rear axels with 4.56's and keep on keeping on as is
    2- Sell the rebuilt CI front Diff, sell the Rancho and install a solid axle
    The issue with option #1 is that I have put a bunch of money into the front end already and I have surpassed the cost of doing a SAS....
    The issue with Option #2 is that this would be all new to me, I can get past that, but with the 37's and the supercharged v8 I think i would need to go with an axle larger then the D44
    My wife and I plan to take a trip up to Alsaka this summer, then down to Baja in the winter..... I would love to have the SAS done for piece of mind, but that is also a lot of pavement miles.... I am slightly worried about loosing the confort that the truck currently has.
    I would love to hear some thoughts as I mull around the two options!
  4. #498
    Street Tire
    Join Date
    Oct 2017
    Salt Lake City, UT
    Posts
    357
    Thanks
    141
    For starters I have no experience here but I'll comment because 1) you're asking, 2) love your rig and kept it on my radar in case it had it was still for sale in 4-6 months and 3) I want to SAS my rig in the future as well...at least I think I do lol.
    I vote for a modified version of option #2, which is SAS it and sell the CI front diff and rancho for dirt cheap to me lol. For real though, SAS it and part out the IFS stuff to re-coupe costs of the SAS. The rancho I think you could sell for $2k+, probably even $3K because people are desperate out there for a bolt on H3 lift. I too worry that SAS will lessen the ride quality, at least not without dumping alot more money into it.
    Couple of questions....
    1. Do you intend on doing the SAS yourself or having a shop do it?
    2. Any idea what rig you'll pull the solid front axle from? I imagine that depends on if you end up needing a D44 or D60
    3. What width for the front SAS do you plan on going with, stock to match rear?
    4. Will it be leaf spring or multi-link? For future upgrades and increased comfort/cost I think you'd want to go with multi-link?
    2006 H3 3.5L I5 Adventure / Luxury / De-chromed / Torsion lift / 35" Goodyear Wrangler Duratracs / Bilstein 5100 shocks / Schwarttzy Skid Plates and High Clearance Leaf Spring Plates / Warrior rear shackles / Solid Axle GM Corporate 10 Bolt rear diff cover / 1" Daystar body lift / Custom Tube Doors x4 / AirDoc / AFE dry filter / OD Steering Rack Reinforcement Kit, Differential bushing kit, and Heavy Duty Tie-Rods / PCM of NC tune / Long Tru-Cool LPD trans cooler and thermal by pass / Snorkel
  5. #499
    Super Swamper
    Join Date
    Jul 2012
    Posts
    2,267
    Thanks
    182
    My brother has a 2wd Jk with 2.5" lift and it drives like any H3 on the road (minus the road noise). Offroad on the desert not as good though
    My friend has a 3.5" lift and his ride is horrible.
    It really narrows down to what shock/spring/swaybar combo you endup going with for ride quality. Too soft and you endup comfy but maybe allover the place, too harsh and you get alot of control but horrible ride.
    06 H3, Birch White, Lux , Cooper AT3 35s, Borla Performance Cat-back, Bilsteins front w/ 1/2" extended stops, Hunner sleeve, Air Doc w/ K&N filter, Oem Roof lights, 55W HID Headlights and 35W Fog lights.
    09 H3 V8, Arctic Silver, LS376/480 Conversion, 3000 stall, Custom E-fans, 37" KM3 tires, XD Rockstar Wheels 17x9, OEM Sliders, 40K External Trans Cooler, Bilstein 5160s front 5100 rear, O.D. Steering Bracket, 2" Body Lift, Custom Exhaust, Custom intake pipe & K&N filter, Custom PCM tune, Pioneer DVD unit, Aurora 40" LED Light Bar, 50 W HID Headlights
  6. #500
    Super Swamper
    Join Date
    Sep 2011
    Posts
    4,118
    Thanks
    179
    Canadian h3t Alpha build
    Having done several H3 SAS’s (and helping out on another dozen or so)...the SAS is definitely a total re-do. It changes the truck drastically, and you will have to compromise in a few areas. The SAS can be tuned for a wide range of use but I prefer to keep them on the mild side. Highway manners, braking, and handling remain very good, even with 5.13s and 37”s. Turning radius is less. Ride height is more. It feels more like an “80s truck”. Best of all...it does not break. When I had the IFS, I was always holding back on some of the more challenging off-road maneuvers. What the solid axle lacks in refinement, it makes up for in durability. Regardless...two constants still remain:
    1. Everything is a compromise.
    2. Anything can be broken.
    Unless you are doing serious off-roading, it’s hard to justify the SAS. Here's an example of what I'm talking about (don't try this with an IFS)...
    https://www.youtube.com/watch?v=BEi7...ature=youtu.be
  7. #501
    Baja
    Join Date
    Sep 2011
    massachusetts
    Posts
    1,093
    Thanks
    219
    Keep the IFS! But I am a little biased...
    Current:
    2006 Red H3 Adventure/ luxury- 37" iroks, HD tierods, steering rack kit, custom front IFS HP Dana 44 diff with Yukon zip locker, Np241 manual T-case, 6.0L VVT/ 6L90 swap
    2008 Black H3 Alpha- HD tierods, steering rack kit, Custom HD lower control arm bushing kit
    2007 Black H3 Luxury- 1.25" bodylift, elocker, 4:1 t-case, steering rack kit, custom front IFS HP Dana 50 diff with truetrac, 37" bfg km2, H3x 18" wheels
    2009 Black H3T base- custom front IFS HP Dana 44 diff with truetrac, 37" centennial trail hogs, H3x 18" wheels
    2008 White H3 Adventure
    2009 White H3 Alpha Cammed 6.0L and 35s
    I think we might have too many of these things now...
  8. #502
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,887
    Thanks
    1,184
    Hey ya'll, I have been quite but still around!
    The T is getting some work done before I take it on a 1400 mile road trip at the end of the month!
    Been getting a crankcase position sensor code every once and a while so I am putting on a new OEM part to see if that will stop the intermittent CEL.
    Haven't been wheeling in a while, but I hope to get out soon for with some overnight camping.
    Still tossing around the idea of SAS'ing the truck, but I with a baby on the way I think the spending will be kept to a minimum!
  9. #503
    Low Profile
    Join Date
    Sep 2020
    SW Florida
    Posts
    166
    Thanks
    32
    Quote Originally Posted by RamRod View Post
    Any updates since March buddy?
    @Gpcalero Instagram photos and videos
    >The Duke H3T Alpha Build Thread<
    '09 Hummer H3T Alpha - "The Duke"
    - LS3 Swap & Built 4L60E
    - Rancho 4" Lift Kit,
    Texas Speed 224/236 Cam 111 LSA Camshaft, ECP 2" Aluminum Radiator, SuperModulation Dual eFans, HID Projector Headlights, 32 Gallon Aux. Gas Tank, "312" Method Race Wheels, Firestone Rear-Axle Airbags, Daystar 1" Body Lift.
    SOLD -- '09 White H3 - "Lil' Sparta"
    - 35" Trail Grapplers, STARR HIDs, LED taillights, Magnaflow Exhaust, Air Doc CAI, Supermodulation TB, Defenderworx Fuel Door
  10. #504
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,887
    Thanks
    1,184
    Not really, I tossed the snugtop back on for winter and have been spending a bunch of time with our new little girl!
  11. #505
    Low Profile
    Join Date
    Sep 2020
    SW Florida
    Posts
    166
    Thanks
    32
    Awww congrats
  12. The Following User Says Thank You to Gpcalero For This Useful Post:
    RamRod (09-14-2020)
  13. #506
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,887
    Thanks
    1,184
    Everything Hummer related has been on the back burner for the past while, but I am starting to plan for some fresh work to the H3T.
    Some of the issues I would like to tackle include:
    Rust - Get rid of the rust starting to form from our dirty salty winters
    Clean up the accessory wiring (find phantom drain hopefully)
    General maintenance and oil changes
    Clean out sun roof track
    Look at installing the rear hydraulic hand brake again (took a break while sorting out options)
    Measure/plan for a possible flat bed build over the winter. I am not pulling the trigger on this project yet but I am getting close, I hope to come up with a design that allows me to make the deck height as low as possible bud does not have fenders sticking above the top of the deck.
    Install new 7" LED headlights
    Re-paint various LED housing back again (starting to chip, fade or oxidize)
    Install mud flaps that cover the wheels for winter (I know its July but Winter comes all too soon up here this far North)
    Make a transfer case skid plate that is flush to the frame like my trans skid.
    Install transmission cooler
    Replace the front locker with a new unit (it has been sitting on my self for 2-3 years now)
    Re-gear to 4.56
    Make new sway bar links (current ones are worn right now and knock with every bump)
    I am sure there is more but that will keep me busy for quite some time.
    I am looking forward to getting out wheelin' again now that my daughter is a little older and I can sneak away for the day.
  14. #507
    Low Profile
    Join Date
    Sep 2020
    SW Florida
    Posts
    166
    Thanks
    32
    Re-gear to 4.56
    I really want to re-gear to 4.56 also, to help with towing. Deff high up on the list!
    What front locker do you have to replace? New OEM or other?
  15. #508
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,887
    Thanks
    1,184
    Quote Originally Posted by Gpcalero View Post
    For the locker I just went with a replacement OEM unit, I found one for 1/3rd the price of an ARB. Plus I didn't feel like rigging up the OEM dash buttons to work with an ARB or similar (although I am sure it would not be that difficult)
  16. #509
    Street Tire
    Join Date
    Apr 2017
    The Motor City
    Posts
    313
    Thanks
    20
    I think this is pretty cool. An H3T with a flatbed and/or the big cargo box with doors like you see in some of the Australian trucks (and a few here in the USA) would be awesome.
    '10 H3T
Similar Threads
  1. Abntroop's 08' H3 Alpha build
    By ABNTROOP in forum Builds
    Last Post: 07-22-2015, 03:50 AM
  2. New Canadian H3T Alpha Owner
    By RamRod in forum Fresh Meat
    Last Post: 03-03-2013, 10:31 AM
  3. Craigslist 2010 H3T Alpha
    By Hans3T in forum Online Finds
    Last Post: 11-05-2012, 08:36 PM
  4. H3T alpha mods
    By nj3talpha in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 11-14-2011, 10:42 AM
  5. H3t Alpha Information
    By kflips in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 10-23-2011, 10:14 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
