H3 Rock Sliders
SoCalH3
Beaumont
When you say mid to late Sept, is that start fabrication? In your H3 build thread, you were considering going with thinner steel with an extra bracket. Is your current plan to use the same thickness as previously? If it's not structural, I'd rather shed some weight by not having a 4th bracket. What would be your best estimate for completion? Thanks
Schwarttzy
Rockford IL
Would hope to be shipping them late September early October. Thinner steel bracket and adding in the fourth mount. I won't be able to get you a good time frame, happy to update you every time some thing get done, but what I can promise is that my jaw will fall off if you manage to break my rock sliders.
SoCalH3
Beaumont
Sounds good! Will they mount to the same location as OEM? Not sure offhand if OEM is 4 brackets or 3?
What do you need from me to get started? I want to move forward with them.
Thanks, Brian
SoCalH3
Beaumont
Wanted to make sure you saw my last post..? What do you need from me to get started? Feel free to PM me. Thanks
H3HummerLineX
SoCal, Chatsworth
This what I did 3/16 steel 3x6. Worked great and I used them hard.
SoCalH3
Beaumont
Thanks for the info, looks good and well built!! My preference would be to bolt it to the frame.
I take it that was done at a local shop? What did it run?
Schwarttzy
Rockford IL
I just want to clarify I'm against welling the sliders on, but it's cool to see what the community has been up to and I need to mention that those welds are beautiful. In the future, if want weld up your own set of rock sliders, I would be happy to get you a set of the same laser cut brackets I use to make mine.
