Results 1 to 14 of 14
  1. #1
    Petroleum Transfer Tech.
    Join Date
    Apr 2012
    The Hat, Alberta, Canada
    Posts
    58
    Thanks
    4
    Air Doc intake tube :)
    Here is my new Air Doc parts installed, nice and clean and got rid of that huge chunk of plastic they called an intake tube.
    New ....
  2. #2
    Unsafe At Any Speed
    Join Date
    Sep 2011
    Minnesota
    Posts
    2,314
    Thanks
    339
    Awesome! AirDoc FTW!
    Gone but not forgotten
    R.I.P.
  3. #3
    Join Date
    Sep 2011
    Posts
    9,606
    Thanks
    722
    Excellent, it's a great product.
  4. #4
    Join Date
    Apr 2012
    Posts
    58
    Thanks
    4
    I just got back from a cruise and it is a noticeable difference, you can hear the engine sucking air and my exhaust sounds a little more throatier. I reset my programmer to towing and just filled up with premium and will see and record the mileage and see if it affects that at all. I noticed my mass air flow is sucking at a higher cfm of air through it as well at 50% load, according to my gauges on my programmer as well.
    Great guys and great product, had very good communication with them and they were more than helpful with my questions.....very easy to install to...20 mins top I believe.
  5. #5
    Bald Tire
    Join Date
    Feb 2013
    ks
    Posts
    1
    Thanks
    0
    Shroud
    [QUOTE=Rig Pig;47219]Here is my new Air Doc parts installed, nice and clean and got rid of that huge chunk of plastic they called an intake tube.
    I ordered the air doc for my 03 h2. Does your filter you have have a 3 and a half diameter inlet? When you ordered your filter did you get the shroud with it? I really want the shroud for the filter but cant find where to order just the shroud. Thanks
    New ....
  6. #6
    Low Profile
    Join Date
    Nov 2012
    Mississauga Ont canada
    Posts
    70
    Thanks
    20
    that be very sexy !!!
    22007 H3 Luxury 3.7 L - Polar Bear brush guard and tail light protectors - GM Roof Marker lights - GM Undercarriage protection - Rough Country level kit - With T-Bar tweak at 24 -Skyjacker 7000 shocks - Crossed drilled rotors - Magnaflow exhaust - Trail Duty extended bump stops - NGK IRIDIUM plugs- AirDoc intake- AFE filter - 315-75-16 LT Eldorado Mud Claws - 55 watt off road lights - More mods planned .007 H3 Luxury 3.7 L - Polar Bear brush guard and tail light protectors - GM Roof Marker lights - GM Undercarriage protection - Rough Country level kit - With- 55 watt off road lights - More mods planned .
  7. #7
    Baja
    Join Date
    Sep 2011
    Posts
    1,097
    Thanks
    1
    Quote Originally Posted by Rig Pig View Post
    ...just filled up with premium and will see and record the mileage and see if it affects that at all. ....
    Just curious, but why the premium? AirDoc shouldn't affect detonation and require higher octane.
  8. #8
    Low Profile
    Join Date
    Aug 2012
    Long beach ca
    Posts
    178
    Thanks
    5
    Rig pig I wanted to get one for my H2. I'm just afraid ill run into code errors and stuff. I have a question on my h2 2005 on the stock plastic intake there is a button looking thing that says reset. What is that for? I don't see it on your set up.
  9. #9
    Street Tire
    Join Date
    May 2012
    Surprise, AZ
    Posts
    491
    Thanks
    10
    That's a little gauge to meter the airflow resistance through the air filter, in other words how dirty the air filter is. When you change the filter you hit the reset button on it.
  10. #10
    Low Profile
    Join Date
    Aug 2012
    Long beach ca
    Posts
    178
    Thanks
    5
    Ok that's for answering that. I just replaced my air filter about 1-2 weeks ago. Guess ill push it to reset it. Thx
  11. #11
    Join Date
    Apr 2012
    Posts
    58
    Thanks
    4
    Quote Originally Posted by Savethereef View Post
    I believe your talking about the air filter indicator, it lets you know when your air filter needs to be replaced. It has no wires or anything to unplug on it, plus I run the Airraid filter now so I visually check it and clean and oil it myself....no need for that little pop button.
    Sent from my super secret shoe device using Tapatalk HD
  12. #12
    Join Date
    Apr 2012
    Posts
    58
    Thanks
    4
    Quote Originally Posted by LoJac963 View Post
    I guess I should read all the posts in stead of just replying to the first one lol.
  13. #13
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,870
    Thanks
    1,170
    Looks way better & clean!
  14. #14
    Join Date
    Apr 2012
    Posts
    58
    Thanks
    4
    Quote Originally Posted by 08H3 View Post
    I run premium just for the cleaner burn and when hwy driving I do get those extra miles out of it for the few extra dollars it cost's.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
