Results 1 to 11 of 11
Thread: Hi lift woes
  1. #1
    Join Date
    Sep 2011
    Posts
    3,484
    Thanks
    811
    Hi lift woes
    I am having troubles lowering my hi lift. I cant seem to push the reverse lever down, idk if its broken or just really stubborn ....thoughts?
    -2009 H3 Alpha/Adv||SAS/SOA
    -2008 H3 Alpha-RIP
  2. #2
    Unsafe At Any Speed
    Join Date
    Sep 2011
    Minnesota
    Posts
    2,314
    Thanks
    339
    I have the same problem with mine. Try giving it taps with a hammer.
    Gone but not forgotten
    R.I.P.
  3. The Following User Says Thank You to M22KLARS For This Useful Post:
    cgalpha08 (04-11-2012)
  4. #3
    Join Date
    Sep 2011
    Posts
    3,484
    Thanks
    811
    All fixed, couple of taps with my foot and pop down she goes!!
    -2008 H3 Alpha-RIP
  5. #4
    Super Swamper
    Join Date
    Sep 2011
    Posts
    2,320
    Thanks
    223
    Try slightly pushing the handle down in lift mode and then push the lever to take some pressure off.
    Sometimes it will also work the other way.
  6. The Following User Says Thank You to Hunner For This Useful Post:
  7. #5
    Street Tire
    Join Date
    Sep 2011
    Ladera Ranch, CA
    Posts
    264
    Thanks
    0
    WD40 works wonders
  8. #6
    Guardian Angel
    Join Date
    Sep 2011
    Raleigh, NC
    Posts
    2,287
    Thanks
    396
    Quote Originally Posted by WarMongur View Post
    WD40 works wonders
    What he said plus the tapping.
    "Ex Umbris Venimus"
    Sent from my iPhone
    Facebook NC Hummer Group
    https://www.facebook.com/groups/NCHummers/
    ReconH3 Build Thread v2.0
    http://www.hummer4x4offroad.com/foru...ld-Thread-v2.0
    ReconH3 Garage
    http://www.hummer4x4offroad.com/foru...age_view&id=35
    Quote Originally Posted by goob3r View Post
    Your truck is HUMMER porn, seriously.
  9. #7
    All Terrain
    Join Date
    Sep 2011
    Nova Scotia, Canada
    Posts
    704
    Thanks
    9
    Tis the nature of the beast. Lube and persuasion is sometimes required.
    Blacksheep HUMMER Squadron : GREAT WHITE NORTH
    Taking the Blacksheep international.
  10. #8
    NERD!!!
    Join Date
    Sep 2011
    Rancho Palos Verdes, CA
    Posts
    3,171
    Thanks
    2,291
    I recommend a silicone based lube instead. Makes less mess. I typically spray mine during a pre-trip inspection. Helps keep the dust out and I don't have to fight it on the trail.
    2020 Subaru Crosstrek Premium / 6 Speed - BUILD THREAD
    SOLD 2006 Hummer H3 / Adventure / 5 Speed / No Bling - BUILD THREAD
  11. #9
    Super Swamper
    Join Date
    Sep 2011
    Posts
    2,320
    Thanks
    223
    WD-40 I don't think is what it used to be. Seems watered down, maybe still a penetration liquid but not much lube quality and attracts dust and dirt and migrates to other surfaces I don't want it on.
    I use the dry lube stuff also.
    PB Blaster is the best for loosening things up and recommends not using WD-40 first or if you do add more PB Blaster to wash it away. Sound like hype to use more of their product but the stuff works! Reading the can is hilarious also.
  12. #10
    Join Date
    Sep 2011
    Who cares!
    Posts
    1,977
    Thanks
    11
    WD-40 is a great moisture remover and displaces water. Used to use it on distributor caps (remember those?) and for cylinder locks in winter after a car wash. But as a lubricant, it is not good and is not long lasting.
    Don't know anything about Hummers, but I do speak Malamute.
  13. #11
    NERD!!!
    Join Date
    Sep 2011
    Posts
    3,171
    Thanks
    2,291
    Quote Originally Posted by f5moab View Post
    Yep, used it a lot when I lived in the Sierras and needed to keep the snow from stalling out the car. Worked great in starters as well. Had one freeze up on me one winter.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
