StandoutAlpha
- Minnesota
[video=youtube_share;fgGrRM1p3ek]https://youtu.be/fgGrRM1p3ek[/video]
Problems The ALPHA has...
-Speedometer moves up and down when revving on PARK ----> (car not moving) **SEE VIDEO**
-Sometimes the speedometer don't even work at all causing the transmission not to shift into the next gear (RPM just revs high until I let off the gas pedal)
-Sometimes it will lag (It won't move/work until I hit a certain speed like for example from 0mph-29mph it won't move or work until I reach 30mph then the speedometer will jump up to at 30mph)
-Only stops working on 1st gear
--ALREADY REPLACED--
-Had my transmission rebuilt a few months ago
-New INPUT speed sensor (Goes inside/internal the transmission)
-New OUTPUT speed sensor (Goes outside/external but in the transfer case housing)
-New OUTPUT speed sensor wire connector
**Bad cluster**??
ALSO
**When I replace/took out the old output speed sensor it had diff oil on it, is that normal? Maybe the diff oil cause it to read the mph erratically?
**Bad cluster**??
ALSO
