I have cleaned the battery posts, Cleaned the selector switch and found the transmission module, under hood on the passenger side ? and cleaned the contacts with a spray and still nothing.
When I push and hold the selector switch they do flash, but none stay on and they are engaging nothing. When I push the traction control switch it does not light up. I don't know it it is suppose too
Time to cut the grass:whaa: And thanks for the help in advance.
First of all, check your brake lights, if your brake pedal switch sensor is broken, then traction control light will arise..
If you dont have brake lights working, first check the brake light fuse in the fuse panel, I fixed a H3 here that had the same symptons than yours, and the problem was the trailer wire hitting the muffler and melting, causing a short, and then blowing the brake light fuse, that result in no 4wd modes working and no traction control and stabilitrack function
In mine, I experienced the pedal brake switch faulty, that results in a no traction control function or stabilitrack, but 4wd modes work....so you need still to investigate a little more, and post here news!
Hope this help you out!
