Results 1 to 8 of 8
  1. #1
    Bald Tire
    Join Date
    Nov 2014
    alabama
    Posts
    18
    Thanks
    0
    HUMMER H3 with 6.0L LS Swap
    2006 Hummer H3 4x4. I swapped the original 5 cylinder with a LS 6.0L LY6 V8 that has LS3 heads and variable cam timing for more torque. Custom programed and dyno tuned so that the gauges, AC, cruise control, ect. all work like stock. There’s only about 60k miles on the motor and 40k miles since the transmission was rebuilt and upgraded. New 35” Mastercraft tires on 20” wheels. Clean leather interior and monsoon sound system with factory sub. Runs and drives great. $13,000. Located in Alabama
Size:  2.88 MBName:  2.jpg
Size:  2.41 MBName:  3.jpg
Size:  2.11 MBName:  4.jpg
Size:  2.96 MBName:  6.jpg
Size:  2.23 MBName:  5.jpg
  2. #2
    Street Tire
    Join Date
    May 2018
    Alabama
    Posts
    324
    Thanks
    18
    Great looking rig. Good luck.
  3. #3
    Join Date
    Sep 2011
    Posts
    9,322
    Thanks
    667
    Agreed, really nice looking H3!
  4. #4
    Street Tire
    Join Date
    Oct 2017
    Salt Lake City, UT
    Posts
    314
    Thanks
    119
    ^ x3. Looks great! Mind sharing how many miles are on the odometer?
    2006 H3 3.5L I5 Adventure / Luxury / De-chromed / Torsion lift / 35" Goodyear Wrangler Duratracs / Bilstein 5100 shocks / Schwarttzy Skid Plates and High Clearance Leaf Spring Plates / Warrior rear shackles / Solid Axle GM Corporate 10 Bolt rear diff cover / 1" Daystar body lift / Custom Tube Doors x4 / AirDoc / AFE dry filter / OD Steering Rack Reinforcement Kit, Differential bushing kit, and Heavy Duty Tie-Rods / PCM of NC tune / Long Tru-Cool LPD trans cooler and thermal by pass / Snorkel
  5. #5
    Bald Tire
    Join Date
    Nov 2014
    alabama
    Posts
    18
    Thanks
    0
    192k on the odometer
  6. #6
    Super Swamper
    Join Date
    Jul 2012
    Posts
    2,001
    Thanks
    127
    What exhaust manifolds did you use? Stock or aftermarket?
    06 H3, Birch White, Lux , Cooper AT3 35s, Borla Performance Cat-back, Bilsteins front w/ 1/2" extended stops, Hunner sleeve, Air Doc w/ K&N filter, Oem Roof lights, 55W HID Headlights and 35W Fog lights.
    09 H3 V8, LS376/480 Conversion, 3000 stall, Arctic Silver, 35s, XD Rockstar Wheels 17x8 Front 17x9 Rear, OEM Sliders, 40K External Trans Cooler, Bilstein 5160s front 5100 rear, O.D. Steering Bracket, Daystar 1" Body Lift, Borla Performance Cat-Back, custom intake pipe & K&N filter, Custom PCM tune, Pioneer DVD unit, Aurora 40" LED Light Bar, 50 W HID Headlights
  7. #7
    Street Tire
    Join Date
    Apr 2017
    The Motor City
    Posts
    259
    Thanks
    13
    Any build threads about the 6.0L swap? If I were looking for an Alpha, I'd be all over this H3.
    '10 H3T
  8. #8
    Bald Tire
    Join Date
    Nov 2014
    alabama
    Posts
    18
    Thanks
    0
Similar Threads
  1. WTS: Dayton Ohio Hummer H3 v8 swap project 4000$
    By rollerlocked in forum The Swap Meet
    Last Post: 08-23-2019, 04:32 PM
  2. Hummer H3 - Door Panel Swap/Upgrade How-to
    By Burtor in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 08-03-2018, 12:53 AM
  3. A little swap
    By Mb30sdl in forum The Firepit
    Last Post: 11-12-2015, 10:58 AM
  4. H3 5.3L Swap
    By KMHOTRODS in forum Builds
    Last Post: 09-28-2015, 12:02 PM
  5. 4:1 swap
    By digglesworth in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 05-27-2014, 09:48 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
