Results 1 to 8 of 8
Thread: Moab Tow Rig
  1. #1
    Low Profile
    Join Date
    Jan 2014
    Utah
    Posts
    195
    Thanks
    168
    Moab Tow Rig
    I have a brother-in-law in his JK broke down at EJS in Moab. Itís weight plus a trailer seems to me to be pushing the towing capacity of my Alpha. Iím approximately 180 miles north from there and havenít done much ďheavyĒ towing. Any thoughts on trying in the Alpha or should I try to find a different towing rig?
    í09 H3 Alpha / Adventure / Lux
  2. #2
    Mud Terrain
    Join Date
    Jun 2012
    Cabool MO
    Posts
    855
    Thanks
    6
    The alpha probably has the power, but the springs cant support much weight. How far do you have to tow it?
    2007 Hummer H3, 3.7L, auto trans, adventure transfer case. Rear locker.
    315/75R16 Nitto trail grappers, Thor parts frt/rr bumpers, 10,500lb winch, OEM rock rails, ucp, rear disconnects, blah, blah, ect.
  3. #3
    Low Profile
    Join Date
    Jan 2014
    Utah
    Posts
    195
    Thanks
    168
    180ish miles
  4. #4
    Mud Terrain
    Join Date
    Jun 2012
    Cabool MO
    Posts
    855
    Thanks
    6
    If you have trailer brakes and the load is not to tongue heavy you may be ok. Since your asking you may be new to towing and then I might advise against it.
    Im towing my H3 into moab tomorrow.
  5. #5
    Low Profile
    Join Date
    Jan 2014
    Utah
    Posts
    195
    Thanks
    168
    Trailer has brakes. Not quite as heavy but I’ve towed a Kabota on it a few times but only 40-50 miles and not through a canyon. I’ve reached out to borrow a diesel but haven’t heard back yet. Sounds like I should be ok if that doesn’t work out. I’ll just drive like an old woman and won’t be making any land speed records. Thanks.
  6. #6
    Mud Terrain
    Join Date
    Jun 2012
    Cabool MO
    Posts
    855
    Thanks
    6
    Just make sure you can adjust the load front to back as needed. I had to add an extra leaf spring on my H3 because it could not support any tongue weight. Now it can handle some extra weight.
  7. #7
    Low Profile
    Join Date
    Jan 2014
    Utah
    Posts
    195
    Thanks
    168
    I’ve seen your build. Wish I could stick around to see it in action.
    I was going to come join the first of the week but time & $ won’t permit.
    Though now I’m spending $ I shouldn’t be spending saving his bacon, so I guess just lack of time now.
    I’m going to shoot in and out either tomorrow night or Sunday afternoon.
  8. #8
    Super Swamper
    Join Date
    Jun 2015
    Posts
    2,003
    Thanks
    534
    Watch your transmission temps as well. If you haven't upgraded with an external cooler, either as an add on or replacement to the internal cooler then you'll want to make sure it's not overheating, especially on the grades up over Soldier Summit. They can get pretty high even without towing.
    2008 H3 Alpha
    "Live free or die: Death is not the worst of evils." - General John Stark
    N1JPA
  9. The Following User Says Thank You to JPaul For This Useful Post:
    Korby7 (04-20-2019)
Similar Threads
  1. Moab
    By f5moab in forum The Firepit
    Last Post: 02-27-2016, 02:02 AM
  2. Moab may 3-5
    By backcountryislife in forum Rockies
    Last Post: 05-08-2013, 09:39 AM
  3. Moab Run?
    By SolidusJ in forum The Firepit
    Last Post: 03-15-2012, 03:13 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
