Results 1 to 14 of 14
  1. #1
    Bald Tire
    Join Date
    Mar 2019
    Usa
    Posts
    1
    Thanks
    0
    Advice on glue/epoxy repairs to front end plastic parts
    Howdy,
    Looking for recommendations for a glue/epoxy that I can use to repair cracked plastic parts for the front grill brace and bumper cover.
    thank you,
    jim
    Attached Images Attached Images
  2. #2
    Join Date
    Sep 2011
    Posts
    9,320
    Thanks
    666
    Relocated to a more appropriate section.
  3. #3
    Bogger
    Join Date
    Jun 2015
    Posts
    1,874
    Thanks
    515
    I have never had good luck repairing the engineered plastics used on vehicles these days. You're better off getting a replacement piece. If you don't want to go that route you could try hot stapling (search ebay for hot stapler, they have cheap ones but I have no idea how good they are). Regular heavy staples (like for a staple gun) heated up and pushed through then folded over to reinforce it then plastic epoxy over it might work too.
    2008 H3 Alpha
    "Live free or die: Death is not the worst of evils." - General John Stark
    N1JPA
  4. #4
    All Terrain
    Join Date
    Sep 2015
    PNW
    Posts
    647
    Thanks
    25
    Easy, the glue you need is made by GM specifically for things like this, the part number is: getanewone
    06 H3 Adv - Great, another project.
    09 H3T Alpha/Adv- Sold
  5. #5
    Baja
    Join Date
    Sep 2011
    Posts
    1,030
    Thanks
    1
    Nothing will work. I tried everything.
  6. #6
    Join Date
    Sep 2011
    Posts
    3,280
    Thanks
    702
    It will probably cost more but this has given me hope for one off pieces in the future
    3D printing, scan the item and have a new one printed for you. Especially since the h3 has all if these unique plastic pieces
    -2009 H3 Alpha/Adv||SAS/SOA
    -2008 H3 Alpha-RIP
  7. #7
    Bogger
    Join Date
    Oct 2012
    Posts
    1,978
    Thanks
    480
    Good old JB Weld.
    2006 H3 Adventure & modified Rancho with SOA
  8. #8
    Bald Tire
    Join Date
    Feb 2019
    SEMI
    Posts
    16
    Thanks
    0
    I just discovered a similar breakage behind my grille. It is low on the priority list but I plan to use loctite superglue. It hasnít failed me yet. JB well if that doesnít hold up, but JB weld wonít be as pretty!
    Out of curiosity was your damage caused by an impact? I havenít had mine very long and was wondering if mine had been run into something. Lower bumper plastic parts are looking poorly aligned so I suspect something was hit at some point, but wondering if it could be a more common issue with the H3 over time.
  9. #9
    All Terrain
    Join Date
    Sep 2011
    Santa Maria
    Posts
    589
    Thanks
    64
    For the parts that are no 6 plastic/ PP; you can plastic weld them. It takes practice and there are plenty of YouTube videos to use as reference. The harder pieces like the external grille would have to be reinforced with glue or fiberglass in some way. Some parts aren't available any more so repairing them via plastic welding is the only option as I determined it. If you plastic weld you need to use the exact same plastic as fill material on the part you're welding. It's kind of a "controlled melt".
  10. #10
    All Terrain
    Join Date
    Sep 2011
    Santa Maria
    Posts
    589
    Thanks
    64
    Quote Originally Posted by Traxx View Post
    Not an option when the parts come up "discontinued".
  11. #11
    All Terrain
    Join Date
    Sep 2015
    PNW
    Posts
    647
    Thanks
    25
    Ebay.
    Quote Originally Posted by Mr_Rich View Post
  12. #12
    Banned
    Join Date
    Jun 2019
    Phoenix
    Posts
    9
    Thanks
    1
    Quote Originally Posted by Bingo View Post
    Howdy,
    thank you,
    jim
    Click here to view more devices.
    Try with the 3M bumper repair on amazon.
  13. #13
    Join Date
    Sep 2011
    Who cares!
    Posts
    1,979
    Thanks
    11
    I have seen technicians do wonders with a plastic welder, and I have also done some plastic repairs that I was amazed lasted for years with JB Weld.
    If the part is not available, and you have no other option, then try a plastic welder if you want to pay a few hundred, it will probably come in handy many times; or try JB Weld it only costs a few bucks.
    Don't know anything about Hummers, but I do speak Malamute.
  14. #14
    Street Tire
    Join Date
    Jun 2015
    Posts
    302
    Thanks
    2
    Since that part (pictured) is not visible, I'd just use some thin (1/16" or 3/32") aluminum and pop-rivets.
    We don't stop playing because we grow old... We grow old because we stop playing.
Similar Threads
  1. What do you use to Restore the look of the Exterior PLASTIC PARTS faded by the SUN?
    By ski.dive in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 01-27-2019, 11:44 AM
  2. Front plastic bumper anyone???? I screwed up...
    By Happy Hummer in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 12-26-2017, 02:04 AM
  3. Wind noise from plastic by the front windshield
    By Ghostbuster in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 10-21-2014, 09:20 AM
  4. Why are plastic parts for the Hummer so expensive???
    By 4u33er in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 08-31-2012, 11:33 AM
  5. plastic parts part numbers??
    By cgalpha08 in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 11-03-2011, 12:29 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
