I finally started the process of stripping all of my mods off the red H3 and transferring them to the Alpha. Yesterday I was able to pull the UCP, OEM rock rails, Thor bumper with winch, roof rack, and pretty much all of the electronics and wiring I had on the front as well as the coax that went up to the antennas on the roof rack.
Today I was able to install my UCP and swap out the rock rails that were on the Alpha with the OEM rails. I prefer how the OEM rails protect the pinch weld, even if it loses some clearance over the rails SuperBuick had built and put on the Alpha when he had it.
I also swapped out the crossmember with the one from my red H3. I know at one point the mounting points had started to fail on the crossmember on the Alpha, though SuperBuick had repaired the one that was broken. However, seeing that this is a V8 and that the crossmember that was on my red H3 was beefed up at the mounting points from the factory, I chose to swap it out so that I wouldn't have to worry about having any issues with it. I'll repair the one from the Alpha using the same technique the manufacturer used on the one from the red H3 and put that in.
It's a bit hard to tell with how dirty the one from the red H3 is, but if you look you can see the manufacturer has added a strap over the top of the bolt tubes (or whatever you want to call them) and welded it in place in several spots. This is a really good fix honestly, because it allows you to really tie those tubes to the crossmember body very well so that you shouldn't have any problems with them breaking off. I really don't know why they have those bolt tubes so close to the edge, the differential pushes down on the crossmember during acceleration (when going forward at least) which then has to be held in place by essentially eight thin strips of 1/8" steel, so it's no wonder they always end up breaking. The 5 cylinder engines probably get away with it more, but the amount of torque the V8 can put down probably wrecks these in short order. I don't understand why they didn't just extend down the brackets on the frame another half inch even and do the same on the crossmember. Then we probably wouldn't be having these issues since there would be plenty of steel above the bolt tubes to handle the stress of the differential pushing down under acceleration. It's almost like whoever was designing this got switched around and thought most of the pressure would be pushing up instead of down.
At any rate, while I have plans to modify the OEM rails to add another tube to use as a step, and I want to make some fixes to my UCP's design, I'm going to wait until the fall most likely. I just don't have time right now what with the Moab trip coming up in less than a month, plus a trip to Colorado at the end of June, and possibly the Rubicon trip in September or whenever they decide to do it. It's also too cold right now to get much done, especially since it has decided to finally start snowing on a regular basis here (We were enjoying 50+ degree days most of January and into February. Now that I have the Alpha and need to get work done on it, it's decided it's time for below freezing weather and snow.). Painting anything would be dubious at best with the cold. Plus I'm still basically the only sysadmin at my company right now (we have a new sysadmin now, but he's got a long ways to go before we can really turn him loose) so not having to work more than 40 hours a week is a pipe dream right now. Hopefully within a month or so though I'll be able to get more free time again to start getting everything else done.
For now my goal is to at least get my tires swapped over (35's are great and all, but since I drive this to and from work every day, they are kind of overkill), and hopefully get the Thor bumper installed as well, including the new Gen 2 pods I got from 4speed a few days ago. That will get me ready enough for the Moab trip, though really as it stands right now it is ready enough, though I should get the CB installed as well since we use that on the trails. But getting the Thor bumper on there would be ideal, since it'll give me more clearance and I won't have to worry so much about bashing my nose on anything.
