Page 18 of 18 FirstFirst ... 81415161718
Results 256 to 259 of 259
  1. #256
    Join Date
    Sep 2011
    Posts
    3,423
    Thanks
    766
    Quote Originally Posted by fanugy View Post
    This post needs a bunch of photos of finished product- very cool and very intrigued
    Oh for sure! I will add more pics once I get the panel mounted inside the cab.
    I did buy off of ebay a transmission cover that doesn't have the coin slot up front. I'll be mounting the switch panel it's self up there. The reason I went with the non coin slot version was that the panel itself is so small that it basically fits in the coin alot itself. So to cut and drill the plastic there wouldn't have worked or looked as clean.
    Sent from my SM-G998U using Tapatalk
    -2009 H3 Alpha/Adv||SAS/SOA
    -2008 H3 Alpha-RIP
  2. #257
    Join Date
    Sep 2011
    Posts
    3,423
    Thanks
    766
    Finally finished my switch pros 9100 install. Stopped in the middle mainly since we bought a house and moved.
    I bought on ebay an early model h3 center console cover that doesn't have the coin tray.
    Switch pros includes a template for where to drill. There are countless bezel snd other options out there, I just chose to surface mount it.
    I ran the line for the panel through this little hole area up in front of the shifter cable.
    The panel also has a sneak peak of some mods that are up and coming as well.
    -2008 H3 Alpha-RIP
  3. #258
    Join Date
    Sep 2011
    Posts
    3,423
    Thanks
    766
    One of the mods I did before I finished the panel was installing some aux lighting on a winch fairlead bracket.
    The bracket was from poison spider, had to slightly drill out the bracket so the 1/2 bolts woukd fit.
    These are Diode dynamic ss3 max combo beams.
    I made a harness for them, all wrapped and pretty.
    They are bright! Haven't tested them out at night yet though.
    -2008 H3 Alpha-RIP
  4. #259
    Join Date
    Sep 2011
    Posts
    3,423
    Thanks
    766
    Since the winch fairlead had to be flipped upside down for the light bracket I figured I would go ahead and upgrade to a factor 55 fairlead.
    -2008 H3 Alpha-RIP
  5. The Following User Says Thank You to cgalpha08 For This Useful Post:
    3Hummers (09-21-2021)
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
