Page 1 of 3 123 LastLast
Results 1 to 15 of 42
  1. #1
    Join Date
    Sep 2011
    Santa Clarita, Ca
    Posts
    9,107
    Thanks
    1,085
    Stall speed in trans
    I read on an old thread that the stall speed is near 1450 on the I-5 H3. Is this the same on the alpha? I had my trans rebuilt and I think the bastard put in the wrong stall speed. Trans is running hotter then ever before. Tested stall speed by foot on brake and gas till it won't raise anymore and it's shows 1800-1900.
    If my stall is 1800-1900 stall
    Stock Chevy 1500 is 1600
    H3 1450...
    That would explain my issues. Is the alpha using the same stall?
    Squeaky3: 06 H3 ALPHA D70 front/Eaton HO72 rear 5.13 gears, custom crossmember for long arms, lockers, 4:1 T-case, v8 swap, hybrid cage, Warn 12k Custom bumpers....do it all vehicle
    "H3 front axles are like drunk cheerleaders....just use em until they get mouthy...then toss em and get another." -anonymous
  2. #2
    Mud Terrain
    Join Date
    Sep 2014
    Chicago
    Posts
    993
    Thanks
    283
    When I purchased my PATC transmission they asked which engine I had and when I told them the I5 they recommended the 1600 instead of the 1800 they put for the V8. I hope that helps.
    2007 Hummer H3 :: 35x12.5R17 Pitbull Rocker Radials | Black Rhino 17x9 El Cajon Wheels | Monster 650HP Trans | ARB Roof Rack | CSF Radiator | Custom E-Fan 12" Pusher | Ultimate Power Steering Upgrade | Scorpworks Bushings | Skyfall Off Road Torsion Bars | Schwarttzy Shackles | Schwarttzy Under Body Protection | ARB Air Compressor | Modified SPOD Control System | 30" Ridged Light Bar | 2 x 4" Rough Country Light Pods | 5 x 13.5 Trail Light Bars | ProComp Leveling Kit & MX-6 Adjustable Shocks | Daystar 1" Body Lift | Detroit Trutrac Locker Rear | Air Doc | ARB Snorkel | 4:1 Transfer Case | Custom Engine Tune | Custom Line-X and Paintwork.
    2000 Humvee in pieces.
    2009 H3T Alpha (SOLD)
    2017 BMW X1 (SOLD)
    2016 4 Runner TRD Pro (SOLD)
    2017 Jeep Cherokee
    2018 Ram 3500
  3. #3
    Join Date
    Sep 2011
    Santa Clarita, Ca
    Posts
    9,107
    Thanks
    1,085
    Thanks, I also got another response via text saying 1800, maybe they put a 1450 in it on accident after the V8 swap?
  4. #4
    Street Tire
    Join Date
    Sep 2011
    West valley, Phoenix AZ (escaped from wacky Madison WI)
    Posts
    409
    Thanks
    38
    I would say 1800 minimum also. I will check what mine is tomorrow and let you know. It's a fresh GM reman I put in a couple months ago.
  5. #5
    Join Date
    Sep 2011
    Santa Clarita, Ca
    Posts
    9,107
    Thanks
    1,085
    I wish I went GM reman instead of this yahoo rebuilding it.
    My original trans didn't have to be rebuilt it still worked great at 135k miles. When I did the V8 swap I had to swap the bellhousing and it was already out so I said why not...had it rebuilt and it kicked ass! Typical 4l60e upgrades. Then I lost a trans line and burnt up the trans. Had the same guy rebuild it and this time it has more delay and requires more throttle input and has way more heat. I'm curious if the first time around he used a I5 stall and this time a V8 stall? Who knows I'm going to call him
  6. #6
    All Terrain
    Join Date
    Dec 2013
    Louisiana
    Posts
    692
    Thanks
    3
    I5 and v8 each use a totally different converter. No way to cross them up.
    Did he actually change the converter on the last rebuild?
    When and where are you seeing higher temps? Off road, normal driving, converter locked or unlocked?
  7. #7
    Join Date
    Sep 2011
    Santa Clarita, Ca
    Posts
    9,107
    Thanks
    1,085
    I would hope he did Casey but I'm not sure. I'm seeing higher temps all the way around. On road, off-road, during normal driving. It doesn't seem to matter what I'm doing, if I'm moving temps are running hotter then ever before.
  8. #8
    Baja
    Join Date
    Sep 2011
    Tulsa
    Posts
    1,087
    Thanks
    226
    I could see a higher stall causing heat buildup around town, but once the converter locks up above 45 mph then it shouldn't be an issue right? A V8 should easily pull a lower converter stall, unless the early lock up puts too much stress on transmission components? I really don't know enough about automatics, hence why I now have a 5 speed.
  9. #9
    Bogger
    Join Date
    Nov 2012
    Santa Clarita, CA
    Posts
    1,706
    Thanks
    5
    Quote Originally Posted by rsc View Post
    i know with the I5 and 35's the lock up occurs way to early and really starts lugging the engine. i usually put my foot into it to get it out of over drive and shift to 3rd.
    2008 H3 3.7 Adventure Package.
    35's BFG K02's, T bar crank.
  10. #10
    Super Swamper
    Join Date
    Jul 2012
    Posts
    2,231
    Thanks
    174
    What trans temps are you seeing exactly?
    If you are running an external trans cooler, check its not clogged or the hoses bent. I don't even know if air can be trapped in it.
    Im running a 3200K stall speed and highway temps are really low 120* in our warm 65* winters .
    Anyway, the alpha stalls at 1800 rpms. The I5 stalls at around 2500. (Thats the rpm speed I used to get immediately when I floor it)
    06 H3, Birch White, Lux , Cooper AT3 35s, Borla Performance Cat-back, Bilsteins front w/ 1/2" extended stops, Hunner sleeve, Air Doc w/ K&N filter, Oem Roof lights, 55W HID Headlights and 35W Fog lights.
    09 H3 V8, Arctic Silver, LS376/480 Conversion, 3000 stall, Custom E-fans, 37" KM3 tires, XD Rockstar Wheels 17x9, OEM Sliders, 40K External Trans Cooler, Bilstein 5160s front 5100 rear, O.D. Steering Bracket, 2" Body Lift, Custom Exhaust, Custom intake pipe & K&N filter, Custom PCM tune, Pioneer DVD unit, Aurora 40" LED Light Bar, 50 W HID Headlights
  11. #11
    Mud Terrain
    Join Date
    Sep 2014
    Chicago
    Posts
    993
    Thanks
    283
    http://www.ebay.com/gds/The-Right-St...0268586/g.html
    Good read. Maybe your getting the heat from too high a stall converter like this article is saying? Now that you are running 40" tires your throwing off your standard measurements?
    2017 BMW X1 (SOLD)
    2017 Jeep Cherokee
    2018 Ram 3500
  12. The Following User Says Thank You to GreatDaneHummer For This Useful Post:
    Panzer07 (03-22-2017)
  13. #12
    Join Date
    Sep 2011
    Santa Clarita, Ca
    Posts
    9,107
    Thanks
    1,085
    Nope these measurements are with 40s and old trans and 40s with rebuilt trans.
    Bypassed oem cooler with 160 thermostat and details cooler.
    Old trans ran at 168 cruising down the highway, new trans 174-176 if I was running hard the old trans would go over 170 but cool back down quickly.
    Off-road crawling in rocks 168 always no matter how I pushed it. New one I was running 180-186.
    Street driving in 100 degree weather pushing it I could hit 190. Street driving in 75 degree weather Can hit 205 and still climbing until I turn it off.
    Off road high speed in sand in hot weather pushing it hard Was the only time I could get the old trans over 200. The new one I feel I can get the trans over 200 in any situation except freeway cruising (haven't been in 100+ yet but can probably hit 200 plus on the freeway when it gets hotter) the only difference between old and new is the actual trans and thermostat location. Thermostat with old one was mounted by the bumper new trans has thermostat mounted off the framerail for a cleaner look but can go back if necessary.
    Only other thing I can think of is reversed trans lines? I can double check that when I get home but I'm 99% sure it's correct
  14. #13
    Super Swamper
    Join Date
    Jul 2012
    Posts
    2,231
    Thanks
    174
    What was the reason for your rebuild?
    Did you replace the cooler after the rebuild? If not then If there were debris in the oil previously (if something broke) is it possible they clogged partially the cooler lines reducing cooler efficiency?
  15. #14
    Join Date
    Sep 2011
    Santa Clarita, Ca
    Posts
    9,107
    Thanks
    1,085
    Rebuild was because I lost a transmission line and lost all fluid and burnt the trans I had a new cooler after the rebuild but when I ran hot I put the old one in thinking that new cooler wasnt as good
  16. #15
    Mud Terrain
    Join Date
    Sep 2014
    Chicago
    Posts
    993
    Thanks
    283
    I'm stumped. If you figure it out please post up. I will hit up my trans guy today and see what he says.
    2017 BMW X1 (SOLD)
    2017 Jeep Cherokee
    2018 Ram 3500
Similar Threads
  1. H3 My trans went out on my 3.7 07 H3, will any year 06-10 trans bolt up or???
    By Jbrown in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 11-03-2015, 11:50 PM
  2. What speed does your H3 shift to 1sr, 2nd, 3rd so on?
    By Happy Hummer in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 07-03-2014, 06:58 AM
  3. 5 speed manual ??
    By Big Mike in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 11-08-2013, 04:01 AM
  4. Speed Kills*
    By Expendable in forum The Firepit
    Last Post: 09-16-2013, 01:53 PM
  5. H3 My Custom Parking stall
    By Medic_Morgan in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 03-18-2013, 11:41 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
