Page 198 of 201 FirstFirst ... 98148188194195196197198199200201 LastLast
Results 2,956 to 2,970 of 3002
  1. #2956
    Low Profile
    Join Date
    Sep 2020
    Kansas City, MO
    Posts
    87
    Thanks
    0
    I changed out my oil pressure sensor last night. (09 V8) The old one had a code for sensor circuit high voltage. Do yourself a favor and buy the special socket for it. I got a Performance Tool W80590 from Advance Auto. GM in their infinite wisdom used some kind of weird rounded off hex instead of a normal 6 point hex. The sensor body is this really light aluminum. It almost feels like tin. It seems like it'd be easy to round off. There's no good way to get an open end wrench down in there, and it would really suck to round the thing off. I was able to do the swap in about 15 minutes with a 3/8" ratchet and extension thanks to that socket. The sensor gets torqued to 25 ft-lbs.
    My sensor also came with a little filter insert. That's only used on the 2010 engines with active fuel management. 2008-2009 doesn't use it. If anyone needs just the filter, let me know and I'll send it to you for free.
  2. #2957
    Street Tire
    Join Date
    Jun 2015
    Posts
    328
    Thanks
    2
    Quote Originally Posted by USMC_315 View Post
    I've been having a leak problem again. Instead of being on the A pillar, this leak is coming from the C pillar and is soaking the headliner on the passenger side. Another strange thing about it is this only happens with the truck is facing uphill, never when it's facing downhill. Any thoughts on what might be going on? I really don't have the means to fix this right now without having any knowledge on what might exactly be going on. Thanks for any help!
    Keep in mind that the channels in the roof for the roof rack rails are bolted into the roof, and extend the entire length. I've heard that the threaded inserts that are used for that channel can rust, and then leak. Thought I'd mention that since you talked about the C pillar, and it would seem that the rear sunroof drains would be nearer the B pillar.
    We don't stop playing because we grow old... We grow old because we stop playing.
  3. The Following User Says Thank You to 650Hawk For This Useful Post:
    USMC_315 (10-20-2020)
  4. #2958
    All Terrain
    Join Date
    Jul 2014
    Northern VA
    Posts
    510
    Thanks
    198
    Finally got around to installing new headlights with the Lased Designs adapter kit for Jeep headlights. Took a bit longer than I expected, but I suppose most of that was due to me running back and forth to the store for things I needed and did not have.
    I also took car of the rattling A pillar trim with some foam tape, seems pretty snug now. The stock foam tape was damn near brittle and about half the size it was from factory it seemed. After these two tasks, went ahead and used some 303 Protectant for the trim pieces to bring back that darkness and it worked pretty damn well. Washed the outside and engine bay for quite a while, gave up before I got to the interior. Next step is to get some bedliner on the grill and some new terminals since mine are cracked. Thank you Bowser-II (for the recommendation, not breaking them). Once that is done, I'll hopefully carve out some time to update my build thread that has laid dormant since before Pepperidge Farm can remember
    2009 Hummer H3 Alpha
    35" Nitto Mud Grapplers
    Gobi Stealth Roof Rack
    Diablo Performance Tune
    Magnaflow custom exhaust
    Bilstein 5100s
    AirDoc Intake Sys.
    Check out my Alpha build thread
    "If liberty means anything at all, it means the
    right to tell people what they do not want to hear"
    -George Orwell
  5. The Following 2 Users Say Thank You to USMC_315 For This Useful Post:
    Bowser-II (10-21-2020), rascole (10-22-2020)
  6. #2959
    Street Tire
    Join Date
    Nov 2015
    Hagerstown, Maryland
    Posts
    215
    Thanks
    104
    Found it causing me to rethink love affair with sunroofs...
  7. #2960
    Bald Tire
    Join Date
    Sep 2019
    Canada
    Posts
    14
    Thanks
    12
    Foglight guards
    I installed some foglight guards. They’re ok, no measurable decrease in light output, and It looks a little tougher.
    Attached Images Attached Images
    2006 H3 Adventure "Tortoise"
  8. #2961
    Street Tire
    Join Date
    Jun 2015
    Posts
    328
    Thanks
    2
    Quote Originally Posted by Gent View Post
    Those are nice...Link?
  9. #2962
    Bald Tire
    Join Date
    Sep 2019
    Canada
    Posts
    14
    Thanks
    12
    Sorry, when I bought it last year, I also got a bunch of stuff buddy hadn’t plastidipped yet. Slowly going through it, lol. Still have a set of lights for the lower grill that needs dipping
  10. #2963
    All Terrain
    Join Date
    Sep 2015
    PNW
    Posts
    681
    Thanks
    25
    Gave it a bath while I charged the battery then took it for a spin to put some fuel in it. Haven't started it since end of May.
    20 Gladiator Rubicon
    06 H3 Adv - Sold
    09 H3T Alpha/Adv- Sold
  11. #2964
    Super Swamper
    Join Date
    Jun 2015
    Posts
    2,102
    Thanks
    552
    I spent 3 hours chasing an electrical problem that was preventing the HVAC blower fan from working. AGAIN. Seems to like to do it around this time of year.
    At least now I have it well sorted as to where the problem is, it's the connector for the body harness just inside the firewall on the driver's side. All I had to do was unlatch the connector and relatch it. That was apparently enough to get rid of the problem. It's a really weird one too, everything has power and proper continuity, except the moment you try to turn the fan on it immediately loses power on the feed side. Turn the knob back to off and immediately you get a voltage reading again. So it was only an issue when there was more than a few milliamps of current flowing through the circuit. Weirdest thing I have ever seen, electrical wise.
    2008 H3 Alpha
    "Live free or die: Death is not the worst of evils." - General John Stark
    N1JPA
  12. #2965
    Baja
    Join Date
    Sep 2011
    Posts
    1,097
    Thanks
    1
    If it's the blower resistor that you are referring to, there was a recall on that. If that's what it is, the problem will only get worse until it quits working altogether.
  13. #2966
    Low Profile
    Join Date
    Sep 2020
    Kansas City, MO
    Posts
    87
    Thanks
    0
    Blower resistor connection is on the passenger side underneath the glove box.
    When I had my dash out, I noticed one of the pins on my resistor connector was dark, like it had been overheated. This is with the supposedly improved recall part. Not cool.
  14. #2967
    Baja
    Join Date
    Sep 2011
    Posts
    1,097
    Thanks
    1
    Sorry...I misread as passenger side. Yeah, I can't believe after all these years someone hasn't come up with an aftermarket GM blower resistor. I've come to expect to replace the one on my truck about every other year. I even bought a new blower thinking maybe it was drawing too many amps, even though bench test showed it was fine.
  15. #2968
    Super Swamper
    Join Date
    Jun 2015
    Posts
    2,102
    Thanks
    552
    Quote Originally Posted by 08H3 View Post
    Not the blower resistor. It's the body harness connector on the driver's side just inside the firewall. The connection there is what is going out on my truck.
    2008 H3 Alpha
    N1JPA
  16. #2969
    Join Date
    Sep 2011
    Posts
    9,608
    Thanks
    722
    Took the H3 to Reloader's today as my rear pinion seal was leaking. Did the driveshaft shake test and realized the transfer case output bushing was worn. Also noticed that the transfer case was moving at the transmission.
    Checked the transfer case mount studs/nuts. Two nuts were completely missing! Two more were about to fall off. One nut was holding the transfer case to the transmission! I need to fire the mechanic that installed it, but then I can't really fire myself.
    So, one pinion seal, transfer case output shaft bushing and seal, new fluid in the transfer case and rear diff. Didn't need to change the fluids but I'm not putting on more than 15K on the transfer case fluid between changes and I was curious how the diff looked since the rebuild two years/12,000 miles ago.
  17. #2970
    Super Swamper
    Join Date
    Feb 2013
    Posts
    3,870
    Thanks
    1,170
    Quote Originally Posted by alrock View Post
    And how did the oil look??
    2009 Hummer H3T Alpha
Similar Threads
  1. What did you do to your H2 recently?
    By Cajun_Tiger_Hummer in forum HUMMER H2 2003-2009
    Last Post: 11-04-2020, 01:20 AM
  2. "what have you done recently" thread got deleted?
    By CaddyStrophic in forum HUMMER talk
    Last Post: 08-23-2016, 09:29 PM
  3. Anyone been to Coal Creek recently?
    By 08H3 in forum The Firepit
    Last Post: 01-16-2016, 05:59 PM
  4. So What Overland Adventure Did You Experience Recently?
    By Bigunit in forum Expeditions and Overland
    Last Post: 10-29-2015, 06:41 AM
  5. H3 Traded your H3 in recently?
    By joe315 in forum HUMMER H3 2006-2010; H3T 2009-2010
    Last Post: 06-29-2014, 12:11 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Logout
