Have the GM Performance cold air intake on my H3. Replaced the alternator, battery, throttle body tire wheel sensors. Now throwing, "traction control stability control failed, reducing power." Suggestions?
If I’m reading this correctly, you replaced wheel speed sensors? I’d start with those. Check all sensor connections. Easiest to identify the culprit if you have a scan tool such as a Tech 2 that can see these, and monitor them as you drive. It’ll tell you which corner. Next, I’d be checking electrical grounds.
