Rodzlla
- Northern Virginia
It has been a little while since I have been focused on my truck. It is a shame really. I noticed a tire going flat a couple days ago. I took it over to Firestone to have it looked at and asked them to check the alignment while they had it.
They called to let me know they patched the tire, but could not address the alignment. They said the right front steering and suspension components have excessive play. They said:
1-right inner and outer tie rod ends need replaced.
2-right front hub assembly needs replaced.
3-lower right ball joint needs replaced.
Their cost was $2,225. That number is too big. I will be doing this work myself.
I need a bit of help. Primarily, I seek your expertise.
Can someone provide the part numbers for the 16mm upgraded versions from Moog or GM? I am also open to upgraded custom ends, if reasonably priced.
I am looking at the Timkin or AC Delco hub assembly. It is hard to argue with the lifetime Timkin warranty, but this is not something I want to do again anytime soon. Thoughts?
I am likely going to replace the lower control arm with a GM part, if I can find one, but what about the Dorman or MAS arms? Is the extra coin spent on GM OEM unit worth it?
