Paladine71
ΜΟΛΩΝ ΛΑΒΕ
- Tallmansville, WV
I think that all of us can agree that flashlights are an essential preparation since flat tires, break downs and emergencies can and do happen at night.
Post up your choices for flashlights and mounts in your rig... :corn:
I have three flashlights in my rig, I believe in redundancy. I may even have a few more light sources if I look.
All three are LEDs, which produce bright light with low power usage.
The one on the left charges off of 12 volts and lights on the end like a regular flashlight, and from the front as a work light. It comes with a hook on the back to hang it as needed and is mounted beside my axe with durable Velcro.
The light in the middle uses regular batteries but has a more focused and brighter beam for distance. I carry this one in my rear door with my jack.
And then, my backup light is on the right. It is charged by winding the charging handle on the back. It never needs batteries or an external electrical source to charge it. After about a minute of winding, it will give you light for around 15 - 30 minutes depending on how many LEDs you use. This one is tucked into one of my Smittybilt G.E.A.R. pouches.
