Ajaxzem
- Byron, Georgia
I got a vicm from an 09 yukon with bluebooth. My onstar has never worked and won't connect anywau so i thought i would try adding bluetooth with the 09 module. I have seen a few posts here and other places like the silverado forums saying the newer onstar modules with bluetooth are plug and play. It adds BT capability but onastar usually doesnt work, spmetimes it does. So i got one from a salvage yard along with the bluetooth antenna. The one i took out has a label on it that says it was made by LG, has two white plug-ins, one screw on coax and one snap on antenna wire with blue connector. The new one has same white connectors, and a bluetooth antenna connector, one that the blue antenna connector will connect to and another snap-on type connector. So im left with a screw-on coax with no way to connect. Not a big deal though as iv'e read that you just connect the two white plug-ins and you got BT. So i did that and the radio immediately said "XM error" and then went blank. Check engine light is the only light on dash and I can't start the hummer. I cant even get the key out of the ignition. No power anywhere. No radio, no ignition, nothing.
If i unplug either connector i get everything back. One connector at a time has no effect, but one white connector and the Blue antenna connector does the same thing. Gauges all drop to bottom, lights all shut off, and ignition is disabled. so this vicm kills my car. No vicm if fine, and the old one is fine but wont connect to onstar. Anyone else had this issue? Everything i have read says its plug and play BT and I can't fine any reason why this would disable the vehicle completely.
