Rear mounted rack
taylorblake831
western washington
Does anyone make a rack for the back door for a jerry can and ammo can to fit on both sides of the spare, and bolts up to the spare carrier? I've been looking for something like this and have found anything.
rsc
Tulsa
I have something similar to that in my shop that I never put on the H3. Can't even remember exactly what it is like it has been so long.
ABNTROOP
HIPPO
Vancouver, Wa
Beware! The spare tire holder has a max weight capacity!! Using your spare as a temp step to get up on your roof rack while static is not a fair evaluation. Adding the weight of fuel cans or water cans is not a great idea unless you want to rip that carrier off the door. I tacked in extra supports inside my door to mount a rotopax "L" bracket to and have 2 x 2.5 gal cans on it. Otherwise get yourself a replacement rear bumper with swing away tire and junk carrier. Truth be told I wouldn't have even done what I did it I'd known I'd score a trailer so soon. I'll be curious to see how the door/ hinges hold up in the long run. Although it'll be a long while as those cans remain empty the majority of the time.
Yea mine is still in testing with about 30,000 miles on the 06 and then transferred to the 08 for 75,000. I think it might work?
Of course ALL of that was not offroad but it stays loaded up on weekends.
I got a copy from the first one made for the rear then bought the bigger version made by someone else.
I explored getting some made but only got a few interested people which did not get a good price point.
A couple of designers of ones with the cans down low had to back up and advertise them as for water only.
Seems there was some concern over liability of having explosive liquids down where they could be struck.
Guess the Jeep ones got around that somehow.
I will try to find some other designs in my files they were like one offs, never got made.
Those threads seem to no longer be with us.
I can fit a size bigger ice chest for extended camping but use the smaller one for short trips.
I carry one water and one gas can.
Ran Moab trails twice with them on.
Here is one design a guy made for an H3 that is more like you described wanting. He was going to market them and some other things but sort of folded up and never made any others.
Should be easy to fab this kind up.
Can't find the one of it mounted on an H3 in the snow.
derian06
Red Rockett
Madison, AL
It's been awhile with my 37's on there, and it's been fine. There is one made by outfitterdesign ImageUploadedByTapatalk1420763336.341006.jpg
Yea but that does not look like it could hold cans without some flooring or brackets and then not wide enough to also add an ice chest?
AMSTAR (later re-named to Boulder Accessories) used to make one. It was aluminum and matched the same appearance as the BA roof rack....
AMSTAR was the original glimmer of hope for Hummer. It was the "hard-core off-road parts company" for Hummer, and there were plans to have a kiosk in every Hummer dealer where you could walk-up and buy cool parts for your Hummer. GM would not let these parts on the option list...but they did agree to make them "dealer installed", or "customer-installed". This was a full-tilt frontal attack on Jeep, and targeted specifically to the off-road crowd. They offered front winch-bumpers, roof-racks, spare tire racks, rock-rails, UCP, beadlock wheels, and some other useful parts. The day the AMSTAR program got cancelled and sold off to Boulder Accessories...we should have seen the writing on the wall. Sad days ahead.
Some of the parts went on to get GM part numbers...the UCP, Rock-Rails, and Hutchenson wheels. The rest of the stuff got liquidated by BA, for very little dough. I've personally owned the BA front bumper and still own a BA rack. The quality is only marginal but, it definitely filled a small niche in the market at a time when there were zero aftermarket parts for the Hummer.
taylorblake831
western washington
Yea that's pretty much what I want, the one at the bottom of hunners post just one on each a side of the spare. And yea it shouldn't be to hard to fab it up but I don't really have anywhere to build it right now
jakesz28
Cabool MO
I had a similar rack on mine for a while. Pics are in a build thread I started a while back. Plan on putting it back on as needed. Used it a lot when camping.
Cyouincourt007
Pavement Prince
Miami,Fl
Point taken, so the caveat is engineer properly, and proceed at your own risk as the weight capacity isn't there "just cuz"
What is the weight capacity if you know by any chance. I'd be interested in something to mount cans back there too but wouldn't want to mess things up either. Thanks
Yeah I replied once before but some of that is lost so I just post again trying to help.
In the case of the big one I have, without the rear brace I get a little movement when I close the door.
Designs with one arm extended out in space may not be steady and could leverage on the bracket being attached further out at the back.
This one I have was engineered for the forces to be in shear against the door. So far I have no issues with the hinges or the latch.
I even ran a 35 back there for awhile.
I think if someone fabbed up the bracket any basket could be fitted to save money. It seems that was the expensive part where I was having the skids made was curving the basket rails to look nice. That and labor to assemble it by welding. I would not trust bolting but did explore a couple of ideas along those lines.
The designer gave me written permission to produce this type but it was coming in at about $600 and shipping would best be done it two pieces.
He cut this one and built crates for the two and I had it welded back when I got it. Also added to the expense.
So I scrapped that idea.
I calculate my mileage fairly accurately and the only time I was concerned with fuel was a two day run in the Mojave. Driving in the deep sand really sucked up more fuel than I anticipated.
Since that time I found out there was a road out along the way where I could make a side trip for fuel, and a cheeesze burger!
This size may not be for everyone but it works for me. I mostly run a mid size ice chest on there.
You do the math, 5 gallons of water, 5 gallons of gas ice chest with drinks and food and ice. I don't remember the weight of the rack but it's heavy and solid.
So two cans of gas would of course be less but I would carry one water and one gas unless you really plan a long wilderness trip.
rsc
Tulsa
I like to travel prepared. That means TWO bags of jerky and a six pack of Mountain Dew.
Yea at least you will be awake for the hike! lol
They don't take no stinkin Visa out here mon! lol
You will be left to the mercy of land Pirates!!
Or you could be left to turn to stone! Petrified Hummer driver.
These guys did not calculate their fuel properly and look what happened to them!
I really NEED a road trip out of cell phone range...............
Cyouincourt007
Pavement Prince
Miami,Fl
Saw an excursion with a rear tank mount on hgwy today . Hard to see but also had like a 50" led bar up front as well at top of windshield.
