SolidusJ
- FT. Carson, CO
Hanging with Frumaker this weekend for a little project I've been wanted to do for a year now, can you tell what we are going to do???
I know of SWEET way to make this work, but you can't be weak about cutting off the frame horns. Once those are gone some 4" C channel will bolt right on to the frame and open your world to ALL kinds of possibilities. Turns out once the C-channel is on there, you now have the same frame set-up as pre-04 Wranglers which means you can find a real winch bumper to squeeze in there. It takes alot of trips to various 4x stores to measure what will fit and look right, but I managed to get a wicked Fab Fours bumper on mine
I should wash my @ss and go to bed but I can't do it without posting up what happen today. Went with C channel that was 8"X 26" and weld it to the center of the frame.
Not sure if we should be flattered or concerned that you put H4O ahead of personal hygiene!
Looks like it is coming along great. Since the Thor's accommodate the OEM lamps why not just use those for now and save that PIAA money for another day?
Interesting execution.
That leaves you a lot of room to play with a new skid plate design.
Are you going to leave that factory crash bar in place or do something else?
What rating is that winch?
I thought I saw a 12.5K sticker on it in one of the earlier pics.
Do you still have access to the clutch lever so you can spool out the cable?
