just having issues with my rack and pinion. I had the old one replaced but now my stabiltrack light is on. My alignment and camber have been adjusted. The light came on as soon as i drove it out of the shop. The brokianic probably turned my steering wheel 360 degrees to connect shaft to the rack and pinion. Rack and pinion is new from Detroit but it has play when steering wheel is turned. I have ordered a bracket that replace the rubber bushing on passenger side and also the new poly bushings for the driver side mount. Now im not sure if i need to buy new steering wheel sensor... any thoughts on this? hehehee
