motley1987
- Delaware
So about a month ago I had my front brakes, rotors and calipers replaced. Not sure if this is related to my issue, but I figured I'd start there. I only noticed it recently, but when I go over a bump or low manhole cover, I get a metallic rattle from both sides. At first I thought it was only from the drivers side but it seems to be from both. I took off the center caps but that wasn't it (that would be too easy of course). I also replaced the front sway bar end links with Moog greasable end links. The sound is almost like banging together two metal pot lids. I thought I could hear it a little when applying my brakes so I'm thinking it's something with the calipers? I've never done brakes so I have no idea what to look for. I also didn't grease the end links since I figured they came with grease in them already which could be a bad assumption on my part. If anyone has an idea of what I should look for, I'd appreciate the help. Thanks!
Been
Been
