poncho1965
- Ridgecrest, California
The in and out on the radiator; which is which? I'm lazy and don't want to figure it out. Thanks!
Mike
Mike
did you find the adapter to the line ends?
May have found one! I had one that came in the kit...
Now I have to test it, see if it fits then order another one.
http://www.etrailer.com/Accessories-and-Parts/Derale/D13018.html
One one of the two would work, the screw on one would screw onto the cooler line.
DO NOT unscrew the quick connect fitting in the radiator. The fitting in the radiator is straight, not tapered threads to start with. That fitting holds the cooler in place in the radiator end tank. If you unscrew both of them the trans cooler will fall into the end tank.
http://www.etrailer.com/p-D13035.html
That's great! Im glad you finished yours, I need to start mine. I haven't had much time since my family from NY is out here.
Driving home from work today I hit trans temps of 212 degrees and it was only 68 out. I don't know how....that's why I went 160 stat. I could pull 255 easy in 100+ and would hit 230+ any time I drove in temps over 90.
Any chance you could post up a couple pics of your install, poncho? Is there a gap to snake the lines through to the front of the condensor to the cooler? Where did you end up mounting the thermostat for it?
Where ya at in Illinois? My bro used to live in Viola, right south of the quad cities.
Mike
I'm in a town called Belleville. It's right across the river from st. louis...
