SolidusJ
- FT. Carson, CO
So I went about my first install with much help from JohBishop. This thing is really stupid simple to install and I don't think I have come by a install for us so here goes my first time on step-by-step.
This is what you'll need, at the moment I have the headlights in and need to order the fog. Headlights are H13 and you can go on ebay and find them on the cheap or go for the more expensive ones. After a few days of research I found that the more cash will give a more white clear color and the cheaper one will give a more blue color, now to find the ones to give you a more white color can be a pain but after looking on youtube you will know what to look for. The bulb isn't what gives off the blue color it's that ballast on how much power it sends to the bulb. More cash more power, less cash more blue color if I understand.
I went with a HID Xenon 8000K with a relay kit. During warm up the bulbs pull a lot of juice and after time that can fry the OEM harness. The relay kit draws power from the battery and the OEM harness sends a single to the relay. Also I can tell with the harness there is almost no warm up time and sometime warm up time can take up to 7 seconds without the harness or how much power the vehicle send the ballast.
Here you can see how it all plug in.
It's going to be a lot more simple to just remove the headlight and there's a golden spot to mount the ballast just behind the head light. I used the double sided tape and 2 zip ties to hold it in place.
The harness has only ONE connector to the OEM light bulb harness. Be sure to cover this connecting point as much as possible, you don't want water getting in there and ruining all you hard work. On the passenger side cover it also and put it somewhere safe and out of the way.
Now the relay harness has a ground wire to each ballast and I just found under the fender there isn't paint under it but still hit all point with a file.
Run the ground into the large hole and then into the new ground point. A zip tie will keep the wire from moving around too much and give a nice clean look. At this time also plug the relay harness to the HID ballast.
Plug in your ballast to the bulbs, there's only one way they go on so don't worry.
When running the relay harness to the passenger side you can go under the center radiator mount. Can't even tell it's there.
When it's all put back together this is how it will look.
Now it's time for get power, I ran my set up to the fuse box. Be sure to remove the fuse in the harness first.
All done and less then 45 mikes and feels great!!! This whole set up with less then $80 dollars. The fogs are on order and the bulb are H10, I'll post up that install in this thread when I have it done.
[video=youtube;oYgxwvrmpgM]http://www.youtube.com/watch?v=oYgxwvrmpgM[/video]
[video=youtube;kaJzXHlffYA]http://www.youtube.com/watch?v=kaJzXHlffYA[/video]
Well I got it all done now, for the relay kit I had to extend both the power and negative that went to the ballast and also the connector to the OEM fog light harness about 8".
