Ru body lifted? If not why dont you go 1" up? You can even do 2", probably helpsAlong the yellow line is where I will further trim the fender...View attachment 26508
Yeah i have the day star 1" not wanting to go any higher than that...I can get about another inch or so if I need by pumping my airbags to max psi.Ru body lifted? If not why dont you go 1" up? You can even do 2", probably helps
Gm 10 bolt with rcv shaft a d ox lockerNice! What axle are you running?
Yes sir bora adapters from 6 to 8 and they just thick enough for me to be a le to push in the hub caps8-lug H2 wheels on adapters? (Noticed your front hubs are hidden).
Sorry for the late reply I'm not as active as I was anyways here it is. Nothing fancy I used some screws they fit perfectlyWhat fog lights are those? Any trick to mounting them in the ARB bezel? My ARB fogs are trashed and I want to replace them.
a monster truckTook Panzer out for a dust off/ car wash at Azusa a week ago...finally made upload a video...enjoy.
Sent from my SM-G998U using Tapatalk
