Torres's 07 H3 A.K.A "Die PANZER"
Panzer07
Ontario, CA
Ru body lifted? If not why dont you go 1" up? You can even do 2", probably helps
Yeah i have the day star 1" not wanting to go any higher than that...I can get about another inch or so if I need by pumping my airbags to max psi.
Panzer07
Ontario, CA
Today was such a productive day got the oxlocker perfectly backslash and gearprint set...then as well the rcvshafts I learned that they are as much of a PITA to get them install as they expensive...I need to cut into the fender plastic liner too so I can get at least 1" of travel in the new 14" bilstein shocks...and waiting in new spindle, hub bearings and races... IMG_20200804_210633_412.jpgIMG_20200804_210633_420.jpgIMG_20200804_210633_415.jpgIMG_20200804_210633_470.jpgIMG_20200804_210633_422.jpgIMG_20200804_210633_421.jpg
Panzer07
Ontario, CA
Finally finished putting the front end all together, now to get a tow and camber alignment and then to test it out to see what. Needs to be adjust or trim with the new tires20200916_185331.jpg20200916_185449.jpg20200916_185647.jpg
Panzer07
Ontario, CA
Replace engine and transmission oil & filters, axle oils...tomorrow I will be dropping down the transfer case to replace rear input shaft bushing & seal...probably run & get around to hook up the airlocker lines and wiring...plenty of small things to address but with this damn heat and sun, in real life time with family, and without an overhead shade wrenching hours are limited to early in the AM or late in the PM...anyways here are some more pics...20201018_183202.jpg20201018_183247.jpg20201018_183342.jpg
Panzer07
Ontario, CA
I haven't been on the forum lately...I'm getting panzer out of non operational status and getting her plated just need to get her smoke.
Sent from my SM-G998U using Tapatalk
Panzer07
Ontario, CA
Converted my steering from ball joints to heim, as well reinforced and notched the transfer case cross member so the driveshaft doesn't rub against it.
Anyways here are some pic from Thursday when I took it out to drive it around so the computer gets some reading before I go get it smokecheck.View attachment 27532View attachment 2753420210624_132611.jpgView attachment 2753620210624_164255.jpg20210624_164321.jpg20210624_164343.jpgView attachment 27537
Panzer07
Ontario, CA
damn I just realized I haven't really updated my build for quite sometime.
some updating have happemd amd spome more are coming up...aiming for May 13, 2024, to have panzer fully Duramax 1 ton swaped.
